Bootloader Issues SAMD21G15B Custom Board Continued
Hello, I'm trying to make a SAMD21G15B work on a adafruit metro M0 protoboard. I removed the board's MCU and replaced it with my preffered chip so I can prove it out for my custom board. I can currently program blinky via atmel studio 7, but my project is arduino based. I also couldn't get any officially supported chips for my project so I'm doing this dance. Very grateful for all of the posts on this- especially posts by MartinL.
I've approached this problem in two main ways.
1.) I created the custom bootloader outlined in this post. My device won't recognize over usb via the arduino IDE after I compiled it in Atmel studio 7 and uploaded to my board. I get nothing on usb when I connect with Arduino using the recommended BOSSA version.
2.) I've also used the bootloader shared in this post. I get the same errors as the OP during upload, but I am able to get the board recognized over USB.
My goal:
-Arduino bootloader for SAMD21G15B
-Crystalless
-Upload via J-link, but USB will work if necessary.
I'm open to skipping the bootloader if I can still use my arduino sketches or import my project into Atmel Studio if it's relatively seemless. Neither seem like great options.
Thanks!
try my_boards M0 to burn the bootloader and use the board.
modify samd/boards.txt as need SAMD21G15B
Thank you for this! Can you help a bit with how to use your files? Digging this deep into arduino is a new thing for me.
there is a README file.
or this can help
Thank you. I should have mentioned that I did take spend a few minutes reviewing the readme file. I'll take a look look at this as well.
if something is unclear then ask.
Thanks! I added my_boards to this location: "\Documents\Arduino\hardware\my_boards"
I'm able to get a COM (USB) connection with the board, but programming times out. When I disconnect USB I get this output. Any thoughts on troubleshooting?
Set binary mode
SAM-BA operation failed
readWord(addr=0)=0x20000ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10011524
version()=v2.0 [Arduino:XYZP] Oct 20 2021 15:22:27
chipId=0x10010024
Connected at 921600 baud
An error occurred while uploading the sketch
Atmel SMART device 0x10010024 found
write(addr=0x20000800,size=0x34)
writeWord(addr=0x20000830,value=0x10)
writeWord(addr=0x20000820,value=0x20001000)
Device       : ATSAMD21G15B
Chip ID      : 10010024
Version      : v2.0 [Arduino:XYZP] Oct 20 2021 15:22:27
Address      : 8192
Pages        : 384
Page Size    : 64 bytes
Total Size   : 24KB
Planes       : 1
Lock Regions : 16
Locked       : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security     : false
Boot Flash   : true
readWord(addr=0x40000834)=0x7000a
BOD          : true
BOR          : true
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.106 seconds
Write 11668 bytes to flash (183 pages)
write(addr=0x20000c00,size=0x1000)
I'd also love to share my bootloader files for my board. A second look would be super helpful if anyone is willing. I'm running crystal less and I'd like to be able to program via USB and directly.
customboard.zip (2.8 MB)
the Serial upload expects the corresponding bootloader. try to burn the bootloader I put there. It is the Arduino Zero bootloader, not a M0 bootloader
EDIT: your bootloader is Zero/MKR bootloader too
I think I missed this. Where did you put a bootloader?
just do "Burn bootloader" in the IDE (over a programmer of course)
No luck. I only have a jlink programmer, and I don't think that can be used with the Arduino IDE.
of course it can be used with the IDE. any SWD programmer works
I've been using ATMEL studio to upload bootloaders and it works fine. My j-link board doesn't show up in the list of programmers and isn't working after a few minutes of tinkering. Is there an advantage for me to figure out uploading bootloaders via the Arduino IDE? If not, I'll just stick with ATMEL studio.
I'm still confused about what bootloader you are providing. Can you clarify?
Capture
sorry. in boards.txt I configured the standard Zero bootloader from the SAMD platform, no special bootloader
Thanks. Can you tell me how this might solve my problem? I can program my bootloader with Atmel Studio. Do you think there is some kind of problem with the programming process that your board.txt file will resolve?
the idea is that the settings in boards.txs for serial upload should match the bootloader used.
There was some analysis of the issue here: https://forums.adafruit.com/viewtopic.php?f=25&p=888967#p888967
Have you looked at the MattairTech stuff at all? They claim to support a large set of "extra" SAMD chips, and it looks like their bootloader Makefile almost works for SAMD21G15A. (I've tweaked it and attached a .hex file that you can try out. If it loads and shows up as a USB device on a host, the IDE integration can come next...) (or is burning the bootloader a problem as well?)
Do you need a bootloader that is explicitly compatible with the existing SAMD bootloaders (BOSSA), or just one that is somehow compatible with the Arduino IDE? As mentioned in the linked post, an 8k bootloader on a part with 32k of Flash is ... depressing.
sam_ba_Generic_x21G_SAMD21G15A.hex.zip (6.3 KB)
Agreed that it uses a lot of the available memory. But, it's surprising how much I can do with 24k! Also, in the world of chip shortages, I'm learning I need to take what I get. I don't need anything special with uploading arduino code- just a reliable tool chain.
Because of one of your earlier posts I looked at MattairTech, but I noticed that the particular chip I'm using wasn't supported so I followed Martin's suggestions and build my own bootloader. Thank you for the bootloader! This is very generous of you. This is a similar spot I ended up on my own. I was able to load the bootloader you sent. And, I can recognize the board in the Arduino IDE. When I upload a blinky sketch the upload stalls out. Any additional help would be super appreciated!
This is what I get:
> > C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\workstation\AppData\Local\Arduino15\packages -hardware C:\Users\workstation\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\workstation\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\workstation\Documents\Arduino\libraries -fqbn=my_boards:samd:mzero_zero_bl -vid-pid=16D0_0557 -ide-version=10813 -build-path C:\Users\WORKST~1\AppData\Local\Temp\arduino_build_297178 -warnings=none -build-cache C:\Users\WORKST~1\AppData\Local\Temp\arduino_cache_474510 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\WORKST~1\AppData\Local\Temp\arduino_modified_sketch_965591\Blink.ino
> > C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\workstation\AppData\Local\Arduino15\packages -hardware C:\Users\workstation\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\workstation\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\workstation\Documents\Arduino\libraries -fqbn=my_boards:samd:mzero_zero_bl -vid-pid=16D0_0557 -ide-version=10813 -build-path C:\Users\WORKST~1\AppData\Local\Temp\arduino_build_297178 -warnings=none -build-cache C:\Users\WORKST~1\AppData\Local\Temp\arduino_cache_474510 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\WORKST~1\AppData\Local\Temp\arduino_modified_sketch_965591\Blink.ino
> > Using board 'mzero_zero_bl' from platform in folder: C:\Users\workstation\Documents\Arduino\hardware\my_boards\samd
> > Using core 'arduino' from platform in folder: C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.8
> > Detecting libraries used...
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
> > Generating function prototypes...
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\sketch\\Blink.ino.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
> > "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\preproc\\ctags_target_for_gcc_minus_e.cpp"
> > Compiling sketch...
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\sketch\\Blink.ino.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\sketch\\Blink.ino.cpp.o"
> > Compiling libraries...
> > Compiling core...
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero\\variant.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\variant.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -g -x assembler-with-cpp -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\pulse_asm.S" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\pulse_asm.S.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\wiring.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\cortex_handlers.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\cortex_handlers.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\hooks.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\hooks.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\itoa.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\itoa.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WInterrupts.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\startup.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\startup.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\pulse.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\pulse.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\delay.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\delay.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_analog.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_digital.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\wiring_private.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_private.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_shift.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\avr\\dtostrf.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\avr\\dtostrf.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\USB\\samd21_host.c" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\samd21_host.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Stream.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\IPAddress.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\Print.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Print.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WMath.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\Reset.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Reset.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\Uart.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Uart.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Tone.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\SERCOM.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\SERCOM.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\WString.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WString.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\abi.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\abi.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\main.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\main.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\new.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\new.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\USB\\CDC.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\CDC.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\USB\\PluggableUSB.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\PluggableUSB.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino M0\"" -DSPIWIFI_RESET=12 -DNINA_GPIO0=13 -DSPIWIFI_ACK=11 -DSPIWIFI_SS=10 "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino" "-IC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero" "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.8\\cores\\arduino\\USB\\USBCore.cpp" -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\USBCore.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\pulse_asm.S.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\samd21_host.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WInterrupts.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\avr\\dtostrf.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\cortex_handlers.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\delay.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\hooks.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\itoa.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\pulse.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\startup.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_analog.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_digital.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_private.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\wiring_shift.c.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\IPAddress.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Print.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Reset.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\SERCOM.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Stream.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Tone.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\CDC.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\PluggableUSB.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\USB\\USBCore.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\Uart.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WMath.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\WString.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\abi.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\main.cpp.o"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\core.a" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\new.cpp.o"
> > Archiving built core (caching) in: C:\Users\WORKST~1\AppData\Local\Temp\arduino_cache_474510\core\core_my_boards_samd_mzero_zero_bl_7cce723a3daedb7b9deb99abc65baef4.a
> > Linking everything together...
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\workstation\\Documents\\Arduino\\hardware\\my_boards\\samd\\variants\\arduino_mzero/linker_scripts/gcc/flash_with_zero_bootloader.ld" "-Wl,-Map,C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.elf" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\sketch\\Blink.ino.cpp.o" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/core\\core.a" -Wl,--end-group
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.elf" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.bin"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.elf" "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.hex"
> > "C:\\Users\\workstation\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\WORKST~1\\AppData\\Local\\Temp\\arduino_build_297178/Blink.ino.elf"
> > Sketch uses 11668 bytes (4%) of program storage space. Maximum is 262144 bytes.
> > Global variables use 2364 bytes of dynamic memory.
> > Forcing reset using 1200bps open/close on port COM34
> > PORTS {COM34, } / {COM34, } => {}
> > PORTS {COM34, } / {} => {}
> > PORTS {} / {COM34, } => {COM34, }
> > Found upload port: COM34
> > C:\Users\workstation\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM34 -U true -i -e -w -v C:\Users\WORKST~1\AppData\Local\Temp\arduino_build_297178/Blink.ino.bin -R
> > Set binary mode
> > An error occurred while uploading the sketch
> > readWord(addr=0)=0x20000ffc
> > SAM-BA operation failed
> > readWord(addr=0xe000ed00)=0x410cc601
> > readWord(addr=0x41002018)=0x10011524
> > version()=v2.0 [Arduino:XYZ] Apr 28 2022 15:52:41
> > chipId=0x10010024
> > Connected at 921600 baud
> > Atmel SMART device 0x10010024 found
> > write(addr=0x20000800,size=0x34)
> > writeWord(addr=0x20000830,value=0x10)
> > writeWord(addr=0x20000820,value=0x20001000)
> > Device       : ATSAMD21G15B
> > Chip ID      : 10010024
> > Version      : v2.0 [Arduino:XYZ] Apr 28 2022 15:52:41
> > Address      : 8192
> > Pages        : 384
> > Page Size    : 64 bytes
> > Total Size   : 24KB
> > Planes       : 1
> > Lock Regions : 16
> > Locked       : readWord(addr=0x41004020)=0xffff
> > none
> > readWord(addr=0x41004018)=0
> > Security     : false
> > Boot Flash   : true
> > readWord(addr=0x40000834)=0x7000a
> > BOD          : true
> > BOR          : true
> > Arduino      : FAST_CHIP_ERASE
> > Arduino      : FAST_MULTI_PAGE_WRITE
> > Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
> > Erase flash
> > chipErase(addr=0x2000)
> > done in 0.106 seconds
> > Write 11668 bytes to flash (183 pages)
> > write(addr=0x20000c00,size=0x1000)
