Hi all,
I just bought an Arduino and I love it so far. I just set this up and it's not working. Cant' figure out why. What I am doing wrong?
Thanks a lot,
Peter
Hi all,
Thanks a lot,
Peter
Start here
AWOL:
Start here
So better to post this in "General Electronics"?
Peterrtt:
I don't know - do you think it is a "General Electronics" sort of question?
Replace the 10K resistor to GND on the switch with a jumper to GND.
Change your switch input mode to "INPUT_PULLUP".
Try again ![]()
Peterrtt:
The instructions tell you how to post questions.
Where to post them is the very least of your problems!
Here is your image:
There might be some benefit to having a 1k resistor in series with the pushbutton in case you were to set that pin to be an OUTPUT in the code and have the button short it out. The correct way to wire it is in any case, as you have with the button to ground and use INPUT_PULLUP to pull the pin up while the button is not pressed.
Your diagram is unclear, but appears to show the LEDs both wired backwards. LEDs in parallel may not illuminate equally and certainly will not if they are different colours.
You need to include your code in the posting itself using "code" tags as per the instructions. As it is, the LEDs - when wired correctly - will be lit when the button is not pressed.
