Having a mental blank - been soldering all day, coding the last couple of hours, neighbor is mowing lawn with some oversized mower, wife is eating some d___ noisy crunchy food, I just can't think.
How do I break a 3-digit number into it's 3 digits?
Got 15 of them in an unsigned int array to break up and spread across 6 MAX7219s, with pairs of them driving 3+3+1 and 2+3+3 to make the 15 groups of 3 seven-segment displays.
I just want to break up each int into 3 bytes that I can then send to the MAX7219s.
C'mon, that's too simple. Thanks guys. Never used modulo before.
GolamMostafa, the hardware/schematics are not important. It's enough to know that I have an array of 15 3 digits ints (0-999) that needed to be broken up into an array of 45 bytes that MAX7219s will display.
I usually keep track when counting things digit by digit, when a digit hits 10 I roll it back to 0 and increment the next, dealing with double rollover at 99 and 999. That way the digits are already broken up when I want to display them.
Spent today mounting a bunch of stuff to large piece of oriented strand board, digging up screws and standoffs, making a stable test environment for the 15 digits with 1284P board, mounting 16 push buttons (one is power), mounting the power supply, mounting the RPi, mounting a couple of little speakers, mounting a 7" LCD display. Next step is putting crimp pins on the button harnesses. Gonna take a break and work in the modulo code first.
Kept it simple, I think I might need to swap ends, or move digits within the MAX7219s.
Even compiled into the overall program correctly the first time:
Me. Never used it. Usually I am doing stuff for speed. In this case it's simple button pushes, one of 15, add to an existing count and show the new total, lock the button out for a second or so. No speed needed at all. I'm out of 4-pin crimp housings, will wire up other stuff in the meantime while I wait for a couple of days on delivery.
For speed, repeated subtraction can beat division, even though it seems ungainly:
// compare two methods of conversion int to string
// 2020-5-23 aarg
unsigned long startTime;
unsigned long elapsedTime;
int maxRepTime = 0;
int maxModTime = 0;
char *res;
Serial.println("series...");
for (int i = 31111; i <= 32000; i++) {
startTime = micros();
res = toStr(i);
elapsedTime = micros() - startTime;
if (elapsedTime > maxRepTime) maxRepTime = elapsedTime;
Serial.print("#=");
Serial.print(i);
Serial.print(" repDiv=");
Serial.print(toStr(i));
Serial.print(" us = ");
Serial.print(elapsedTime);
res = toStrMod(i);
if (elapsedTime > maxModTime) maxModTime = elapsedTime;
Serial.print(", modDiv=");
Serial.print(toStrMod(i));
Serial.println(elapsedTime);
Serial.print("max rep method time = ");
Serial.println(maxRepTime);
Serial.print("max mod method time = ");
Serial.println(maxModTime);
char* toStr (int val) {
static char result[6];
strncpy(result, "00000", 6);
const int decade[] = {10000, 1000, 100, 10};
for (int index = 0; index < 4; index++)
while (val >= decade[index])
result[index]++;
val -= decade[index];
result[4] += val;
return result;
char* toStrMod (int num) {
for (int len = 4; len >= 0; --len)
result[len] = num % 10 + '0';
num /= 10;
result[5] = '\0';
return result;
prints (showing just the last few lines...)
#=31997 repDiv=31997 us = 32, modDiv=31997 us = 84
#=31998 repDiv=31998 us = 32, modDiv=31998 us = 84
#=31999 repDiv=31999 us = 32, modDiv=31999 us = 84
#=32000 repDiv=32000 us = 20, modDiv=32000 us = 84
max rep method time = 40
max mod method time = 92
I'm not sure if this will be helpful, but a few years ago I wrote some code on a different microcontroller P8X32A (Parallax Propeller) that controls a 6 digit 17 segment display. The display was connected to two PCA9555's, one controlled the digits, the other controlled the segments. It was alot of multiplexing. I was intending on using 3 homemade modules to control 3 sets of displays over I2C. But, if you watch the video, you can see all the flickering I was getting. SPI bus expanders would have been much faster. Also note that the micro I used is 8 core 80Mhz.
CrossRoads:
[...] the hardware/schematics are not important. It's enough to know that I have an array of 15 3 digits ints (0-999) that needed to be broken up into an array of 45 bytes that MAX7219s will display.
cc-type 15x3-digits array would require 6 MAX7219 chips as drivers. Naturally, I would be interested to see how you have done the cascading and also the coding to see the method of initialization and handling the display.
