Breaks between LED sequence
Can someone help me. In the German forum has "Jurs" wrote this code, but the problem is, I can't make determine breaks between the LED lights sequence, because "delay(1000);" don't work right ? How I can do that?
// Struktur für eine LED
struct led_t { byte pin; int zeit; char wert;  };
// Array für alle LEDs
led_t leds[]={
  { 2, 500, 'A' }, // Red PIN 2
  { 3, 200, 'B' }, // Yellow PIN 3
  { 4, 100, 'C' }, // Green PIN 4
  { 5, 200, 'D' }, // Blue PIN 5
char playList[]="BCABDCBADBCABDCBADBCBADCBBCBCDABBDCABDC";
int playIndex=0;
int ledIndex=0;
#define NUMLEDS (sizeof(leds)/sizeof(leds[0]))
void setup () {
  Serial.println("Start");
  for(int i=0; i<NUMLEDS; i++)
    pinMode(leds[i].pin, OUTPUT);
  Serial.print(leds[ledIndex].wert);
  digitalWrite(leds[ledIndex].pin,HIGH);
unsigned long letzterWechsel;
  static byte start = 0;
  if(millis()-letzterWechsel >= leds[ledIndex].zeit && !start)
    letzterWechsel+= leds[ledIndex].zeit;
    digitalWrite(leds[ledIndex].pin,LOW);
    playIndex++;
    if (playIndex>=strlen(playList))
      start = 1;
      playIndex=0;      // Am Ende Überlauf auf null
      Serial.println(); // Neue Zeile auf Serial beginnen
            while(1);  // Ende mit Endlosschliefe
     if (playList[playIndex]=='A') ledIndex=0;
     else if (playList[playIndex]=='B') ledIndex=1;
     else if (playList[playIndex]=='C') ledIndex=2;
     else if (playList[playIndex]=='D') ledIndex=3;
Incorrect. Any call to delay(), however unnecessary, will work, for some definition of work. Where did you put the call to delay()? What actually happened?
Ok, I have embed delay() in the code but the LED lights up for 1000 ms and and low for 1000 ms the array control don't work I can't say to the LED lights up for 200ms and after that go down for 1000ms before the next LED will be rise up? I don't know I`m not sure what I can do more ?
Where ? Please post your revised program.
