Hi, I am new at this. I saw this project online and thought its cool. I want neopixel LED to fade in and out. I got the light hook up the the Arduino Uno, and plugged in a simple rainbow code, it works.
Then I tried to use the code below and it wouldn't compile. It just told me to come to this website to learn why it would not compile. Currently the light DI is in pin 6. Button input is in 2.
This is the code that won't compile. I would also like to add a button to operate the light.Can you tell me what I can do? I am new and i don't know programming, please go easy on me. I am just learning.
Thank you very much.
// Breathing effect
// Color shifts from hueA to hueB as it pulses.
// Set A and B to the same hue if you don't want the color to
// change. Saturation for the high and low can also be set.
// Marc Miller, 2015
// Updated Aug 2020 - removed delay, added dim8_video
#include <FastLED.h>
#define LED_TYPE WS2811 //WS2811, WS2812, WS2812B
#define COLOR_ORDER RGB
#define DATA_PIN 6
#define NUM_LEDS 12
#define BRIGHTNESS 255
CRGB leds[NUM_LEDS];
static float pulseSpeed = 0.5; // Larger value gives faster pulse.
uint8_t hueA = 15; // Start hue at valueMin.
uint8_t satA = 230; // Start saturation at valueMin.
float valueMin = 120.0; // Pulse minimum value (Should be less then valueMax).
uint8_t hueB = 95; // End hue at valueMax.
uint8_t satB = 255; // End saturation at valueMax.
float valueMax = 255.0; // Pulse maximum value (Should be larger then valueMin).
uint8_t hue = hueA; // Do Not Edit
uint8_t sat = satA; // Do Not Edit
float val = valueMin; // Do Not Edit
uint8_t hueDelta = hueA - hueB; // Do Not Edit
static float delta = (valueMax - valueMin) / 2.35040238; // Do Not Edit
void setup(){
Serial.begin(115200); // Allows serial monitor output (check baud rate)
delay(2000); // Startup delay
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(BRIGHTNESS);
FastLED.clear();
FastLED.show();
Serial.println("Setup done. \n");
void loop(){
float dV = ((exp(sin(pulseSpeed * millis()/2000.0*PI)) -0.36787944) * delta);
val = valueMin + dV;
hue = map(val, valueMin, valueMax, hueA, hueB); // Map hue based on current val
sat = map(val, valueMin, valueMax, satA, satB); // Map sat based on current val
for (int i = 0; i < NUM_LEDS; i++) {
leds = CHSV(hue, sat, val);
- // You can experiment with commenting out these dim8_video lines*
- // to get a different sort of look.*
leds.r = dim8_video(leds*.r);
leds.g = dim8_video(leds.g);
leds.b = dim8_video(leds.b);
_ }
FastLED.show();*_
} // end_main_loop
