Bug Report - Time Picker Widget uses wrong timezone
Timepicker widgets in dashboard show UTC even though I set the timezone to America/Los Angeles in the Thing Metadata from which I associated the variable. I have a sketch that shows the local time correctly. Additionally I get this error: Uncaught TypeError: lu.match is not a function, when I select a date in the date selector and then when entering the date and time in the datepicker widget the date and time are changed to some other value, not what I entered. I could give you the code but this can be demonstrated without code. Just create a thing with a cloudtime variable, set the timezone to America/Los Angeles in the Thing metadata, create a dashboard with a time picker widget and associate the variable then the widget shows the wrong timezone (UTC).
This behavior has been corrected in the latest Cloud UI.
