Building A State Machine Using 2 Modes, 2 Switch Cases, 2 Buttons
I'm trying to build a state machine for a project I'm working on and I can't get the sketch to work properly. My problem is, for example, if I'm in 'mode-1 Red' and push the 2nd button to go into 'mode-2 theater-chase', mode-1 is still active in the background and 'bleeding' through into mode-2 wherever a pixel is "off/black". So I guess I'm trying to find a way to shut off mode-1 when going into mode-2. The closest I've gotten to a solution is to purposely turn off the other mode (you can see what I'm talking about in the commented-out lines in the sketch), but that's preventing button1 from working again when I do want to use it.
I'm open to all suggestions.
#include <WS2812.h>
const int button1 = 2;
const int button2 = 3;
const int button1Led = A4;
const int button2Led = A5;
int mode1;
int mode2;
int mode;
const int ledPin = 6;
const int numLeds = 74;
//Solid Colors
const int cOFF = 0;
const int RED = 1;
const int BLUE = 2;
const int GREEN = 3;
//Patterns
const int pOFF = 1;
const int THEATER_CHASE1 = 2;
const int THEATER_CHASE2 = 3;
const int THEATER_CHASE3 = 4;
int currentColor = cOFF;// the current state we're in at any given time. We want to start in "off", so we set the variable to sOff when we declare it.
int nextColor = RED; // we need to have somewhere to go when we leave sOff, so let's pick red
int currentPattern = pOFF;
int nextPattern = THEATER_CHASE1;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(74, 6, NEO_GRB + NEO_KHZ800);
  pinMode(ledPin, OUTPUT);
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  strip.begin();
  strip.show();
  mode1 = digitalRead(button1);
  mode2 = digitalRead(button2);
  if (mode1 == HIGH) {
    mode = 1;
    switch(currentColor)
        case cOFF:
          Serial.println("off");
          if (digitalRead(button1) == HIGH){
          else if (digitalRead(button1) == LOW) {
            currentColor = nextColor;
        case RED:
          Serial.println("RED");
          if (digitalRead(button1) == HIGH) {
            Red();
            currentColor = RED;
            nextColor = BLUE;
          else if (digitalRead(button1) == LOW){
        case BLUE:
          Serial.println("blue");
            Blue();
            currentColor = BLUE;
            nextColor = GREEN;
        case GREEN:
          Serial.println("green");
            Green();
            currentColor = GREEN;
            nextColor = RED;
      default: // the default case, which is an error for us
          Serial.println("ERROR: default state");
          nextColor = cOFF;
  if (mode2 == HIGH) { mode = 2; }
    switch(currentPattern)
        case pOFF:
          if (digitalRead(button2) == HIGH) {
          else if (digitalRead(button2) == LOW){
            currentPattern = nextPattern;
        case THEATER_CHASE1:
          Serial.println("theater chase1");
          if (digitalRead(button2) == HIGH){
            TheaterChase1(50);
            currentPattern = THEATER_CHASE1;
            nextPattern = THEATER_CHASE2;
        //  currentColor = cOFF;
        case THEATER_CHASE2:
          Serial.println("theater chase2");
            TheaterChase2(50);
            currentPattern = THEATER_CHASE2;
            nextPattern = THEATER_CHASE3;
          else if (digitalRead(button2) == LOW) {
        case THEATER_CHASE3:
          Serial.println("theater chase3");
            TheaterChase3(50);
            currentPattern = THEATER_CHASE3;
       //   currentColor = pOFF;
          nextColor = pOFF;
  if (mode == 1)
      digitalWrite(button1Led, LOW);
      digitalWrite(button2Led, HIGH);
  if (mode == 2)
      digitalWrite(button2Led, LOW);
      digitalWrite(button1Led, HIGH);
  Serial.println(mode);
void Red(){
          for(uint32_t i = 0; i<numLeds; i++)
            strip.setPixelColor(i, 0xff0000);
            strip.show();
void Blue(){
            strip.setPixelColor(i, 0x0000ff);
            strip.show();
void Green(){
            strip.setPixelColor(i, 0x008000);
            strip.show();
void TheaterChase1( int SpeedDelay) {
  for (int j=0; j<1; j++) {  //do 1 cycle of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < numLeds; i=i+3) {
        strip.setPixelColor(i+q, 0, 100, 0 );    //turn every third pixel on
      strip.show();
      delay(SpeedDelay);
        strip.setPixelColor(i+q, 0,0,100);        //turn every third pixel off
  strip.show();
void TheaterChase2( int SpeedDelay) {
        strip.setPixelColor(i+q, 100, 0, 0 );    //red. turn every third pixel on
      strip.show();
      delay(SpeedDelay);
        strip.setPixelColor(i+q,100,100,100);   //white. turn every third pixel off
  strip.show();
void TheaterChase3( int SpeedDelay) {
        strip.setPixelColor(i+q,  0xff8c00);    //orange turn every third pixel on
      strip.show();
      delay(SpeedDelay);
        strip.setPixelColor(i+q,0x4B0082);   //green. turn every third pixel off
  strip.show();
Thanks for the suggestion. If I move it to the top, button1 doesn't work at all because it's constantly being blocked.
    mode = 2;
I'm not sure what you mean. Can you show me a small example?
Why not use switch/case based on the mode and switch/case to determine which code to run in the current mode ?
OK, I get it. But now neither button works. Maybe it's because both modes are starting in the same state...?
But I'll continue to play with your suggestion for awhile. Let me know if you come up with another idea.
How about you post your code as it is now
Try this code
      mode = 1;
      switch(currentColor) {
        case cOFF:  Serial.println("off");
        case RED:   Serial.println("RED");
                      Red();
                      currentColor = RED;
                      nextColor = BLUE;
        case BLUE:  Serial.println("blue");
                      Blue();
                      nextColor = GREEN;
        case GREEN:
                      Green();
                      nextColor = RED;
                nextColor = cOFF;
      mode = 2;
      switch(currentPattern) {
          case pOFF:  Serial.println("off");
                        TheaterChase1(50);
                        TheaterChase2(50);
                        TheaterChase3(50);
                      nextColor = pOFF;
Isn't this exactly what I originally had?
I see it now Delta_G.
Here's a quickie of my buttons:
well that didn't work. let's try attaching:
How about deriving the mode using something like
mode = digitalRead(button1) + (2 * digitalRead(button2));
This will give you modes 0, 1, 2,and 3
Ignore any that you are not interested in, probably 0 and 3
