Hi. I am having troubles switchting the built-in LED of my MKR1000. The device is new.
I have tried the standard example "basics->blink" without success:
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
I have also tried to use port 6 and 13 without using the constant LED_BUILTIN just in case. Further I used a small program (found searching google) that iterates through all ports.
Nothing works and the built-in LED (L) stays off.
The MKR1000 seems to work fine otherwise however, as I can run examples like "WiFi101->SimpleWebServerWiFi".
I can only think that the LED is actually defect. Any other ideas what to try out, or what am I doing wrong? Thanks!
The MKR1000 LED is on pin 6 rather than 13 as on the Uno and Mega. LED_BUILTIN should also work. I don't know why the LED on your board isn't working, that blink sketch should definitely work so it sounds like you have a bad LED on your board.
Pert, thanks for your reply. It is indeed the LED that is the problem. I have now measured with a voltmeter, while running the blink sketch. It jumps from 0V to ~3V and back as expected.
Before you send them back you should change "built in" for the ACTUAL pin
pinMode(6, OUTPUT);
digitalWrite(6, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(6, LOW); // turn the LED off by making the voltage LOW
That would confirm for sure that it is indeed the LED.
One of the IDE;s (not sure which) had an issue and did not correctly set pin 6 for the MKR when calling built_in.
