I've been working on an led matrix project. It uses a built in Atmega328p microcontroller. The schematic is attached. I've been following this tutorial: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
The only difference being that all my parts are smd. When I tried to burn the bootloader to it the first time I got:
Error while burning bootloader.
Then I got rid of c4 and shorted it's pads, and got this:
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Does anyone know how to solve this issue because I'm not sure how to check if the chip works, and I'm not sure what the -F override command is
pert
June 1, 2019, 8:02pm
2
Please do this:
(In the Arduino IDE) File > Preferences
Check the checkbox next to "Show verbose output during: upload
Click "OK"
Tools > Burn Bootloader
After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
Nathaniel_:
Forget about that. It won't help.
this is the full output
Arduino: 1.8.5 (Mac OS X), Board: "Arduino Nano, ATmega328P"
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1411 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/raybechard/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1411
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9516
avrdude done. Thank you.
option enabled in File -> Preferences.
I'm not sure exactly what it means but i think the microcontroller works since avrdude has found it's adress(0x1e9516)
pert
June 1, 2019, 8:49pm
4
Device signature 0x1e9516 shows you have an ATmega328PB, not an ATmega328P. For the ATmega328PB, you can use MiniCore:
Arduino hardware package for ATmega8, ATmega48, ATmega88, ATmega168, ATmega328 and ATmega328PB - GitHub - MCUdude/MiniCore: Arduino hardware package for ATmega8, ATmega48, ATmega88, ATmega168, ATme...
Be sure to follow this part of the installation instructions:
Note: If you plan to use the *PB series, you need the latest version of the Arduino toolchain. This toolchain is available through IDE 1.8.6 or newer. Here's how you install/enable the toolchain:
Open the Tools > Board > Boards Manager... menu item.
Wait for the platform indexes to finish downloading.
The top is named Arduino AVR boards. Click on this item.
Make sure the latest version is installed and selected
Close the Boards Manager window.
After installing MiniCore, you can select Tools > Board > ATmega328 and then Tools > Variant > 328PB .
Please let me know if you have any questions about using MiniCore.
It still dosen't seem to work, but I think it's beacause the atmega328P and 328PB have different pinouts
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/raybechard/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.3/avrdude.conf -v -patmega328pb -carduino -P/dev/cu.usbmodem1411 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0b11110110:m -Uhfuse:w:0xd7:m -Ulfuse:w:0b11111111:m
avrdude: Version 6.3-20171130
System wide configuration file is "/Users/raybechard/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.3/avrdude.conf"
Using Programmer : arduino
AVR Part : ATmega328PB
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 425479
Firmware Version: 16783876.-1494053036
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
Arduino: 1.8.9 (Windows 7), Board: "Arduino Uno"
It has nothing with compilation. It is an error during uploading process of already compiled program.
Communication is so simple that there is hard to have some sophisticated error analyzer. Consider how small the MCU is, with really small memory and just few instructions.
Problem is -F advice for n00bs, it is misleading for them.
Try flashing using the avrdude directly
