Hi Guys,
I am currently designing a button box, and as all projects research is needed.
I have never used a rotary encoder, but have looked into how to use and code.
Hopefully mine will arrive shortly for me to play....
This question is using a Leonardo is it possible to use 5 encoders (non polling.)
I see that the Leonardo has 5 External Interrupts as shown Reference/AttachInterrupt
I also understand that to use the encoder will need at least 2 interrupts per encoder.
However i have read that it may be possible to use a single external interupt pin and a (a)nother pin non interupt for the other output for the encoder ?? but cannot find the article i read a month ago.. >:(
Also it would seem that the 5th External Interrupt ( pin 7.) will need some code adjustment ..
External Interupts 5th Pin Adjustment Code
If you have any possible any suggestion or code suggestions welcome.
Thanks
Neil
