Button Press
How can I make a button only record 1 hit per button press. Right now the loop happens so fast it sees that the button state is on high many times and adds like 100 hits per second. Will something like debounce help? Can someone please give me help. I would really appreciate some sample code.
  buttonState = digitalRead(buttonpin);
   lcd.setCursor(0, 1);
  if (buttonState == HIGH)
   presses = presses + 1;
Debouncing handles when the switch bounces on/off/on/off due to mechanical action of the springs. Your problem is more simple, you keep incrementing while the button is pressed, so if it goes up 100 for one press you are probably holding it down for 1/10th of a second or so.
Look in your Examples folder of the IDE (Examples menu). There is a debounce example that not only debounces, it checks for the button changing state.
A button is a digital input device. It has two states, HIGH and LOW. Detecting it is as simple as digitalRead(button_pin).
On the other hand, if you want to detect a press, that is different, you want to detect essentially a transition from LOW to HIGH (or HIGH to LOW if you use pull-up resistor). To detect transition (in calculus terms, to calculate a derivative), you need to save the previous button status from the previous iteration and compare it with the current reading. If the previous state is LOW and the current is HIGH, you got a press, and you can do what you want when a button is pressed, such as increment a variable. Apparently you need a variable to hold the previous state of the button and overwrite it every time at the end of an iteration with the current value.
Give it a try see if you can make it work. It should look like this:
start with previous state as LOW state
loop:
read current state
if previous state is LOW and current state is HIGH, button is pressed and do something as a response
update previous state with current state
loop end:
mykiscool:
If all you want is to count wait after a press, then a simple option is to use delay()
    wait(1000); // no other key presses read for 1 second
When you're comfortable with delay code, look at the BlinkWithOutDelay example (Arduino menu, File; Examples; 2.Digital) to see how to avoid stopping your whole program for that one second...
There is also a nice library that takes care of all this:
Nice and easy to use. Have a look at the examples.
http://www.arduino.cc/playground/Code/Bounce
