Hi i'm new with the Arduino stuff and I'm looking for some help, I have the code for the state change in the example, and it only works with one button push, I was wanting to know about add one one more and how, I wanting a timer with 2 buttons for a race and one button will start it and the other will stop it, is there anyone that could show me how to do this?
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter % 4 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
This the code from Example that I was going to use, but i was need it to display time in sec and mins or how ever i can get it.
