Hi all,
I have been battling away with my first arduino project and now have it doing what I want...
I now want to be able to start my loop to run once with the press of a push button and then when finnished await the next push of the button.
I also want to be able to (in the future) add in other loops in the program linked to other buttons so I can in effect choose which loop to run by what button I press.
I'm pretty sure the answer will be 'if' or 'while' loops but not 100% on howto implement it.
Here is my code, everything in the void loop is my first program to be run once with the push of a button.
thank you in advance
#include <PID_v1.h>
// code to increase pressure to 140 bar in increments with 5 second delay inbetween increases before unloading to zero, waiting 10 seconds and repeating.
int starttime1; //start time and end time for each while loop
int endtime1;
int starttime2;
int endtime2;
int starttime3;
int endtime3;
int starttime4;
int endtime4;
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint, 0.001, 0.6, 0.001, DIRECT); //tuning parameters P,I,D
Input = analogRead(A0); //pressure sensor signal
myPID.SetMode(AUTOMATIC);
analogWrite(5,0);
myPID.SetTunings(0.001,1.0,0.001);
starttime1 = millis(); //record starttime for while loop below
while ((endtime1 - starttime1) <= 32000) //subtracts start time from end time so loop runs for 32 seconds
Setpoint = 90; //ten bit number for 35 bar assuming full scale 0-400 bar = 0-1023
Input = analogRead(A0); //read input from pressure sensor
myPID.Compute(); //compute relavent output from tuning parameters and sensor reading
analogWrite(5, Output); //send output to propertional valve
Serial.print("pressure = ");` //next three lines to interpret sensor signal and print the corresponding pressure on serial monitor
Input=Input*.391; //calculate pressure in bar from 10 bit number
Serial.print(Input);
Serial.println(" BAR");
delay(1000); //1 second delay to allow things to settle
endtime1 = millis(); //record end time for while loop
Serial.println("5 second pause");
myPID.SetTunings(0.0001,0.3,0.02);
delay(5000);
starttime2 = millis();
while ((endtime2 - starttime2) <= 32000)
Setpoint = 180; // 70 bar
myPID.Compute();
Input=Input*.391;
endtime2 = millis();
myPID.SetTunings(0.00001,0.25,0.02);
delay(5000);
starttime3 = millis();
while ((endtime3 - starttime3) <= 32000)
Setpoint = 256; // 100 bar
myPID.Compute();
Input=Input*.391;
endtime3 = millis();
myPID.SetTunings(0.00001,0.26,0.02);
delay(5000);
starttime4 = millis();
while ((endtime4 - starttime4) <= 32000)
Setpoint = 358; // 140 bar
myPID.Compute();
Input=Input*.391;
endtime4 = millis();
Serial.println("10 second pause and restart");
analogWrite(5,0);
delay(10000);
