Hey guys!
As my first project using Arduino I'm trying to make a movie start and stop by the press of a button. I'm pretty new to coding so under the advise of some friends I'm using Processing to put this project forward.
So far, with the code as it the video starts with the program and when the button is pressed it only stops for a fraction of a moment. I tried changing the variables for when the video start (set the Arduino to send 1 when LOW instead of HIGH. On processing changed the value that trigger the video). And also trying messing up with the delay() in the Arduino side trying to see if would change something, so far nothing.
I can't see where the mistakes are.
Any help would be welcome!
Thanks.
Follow the codes:
Arduino
int switchPin = 4; // Switch connected to pin 4
pinMode(switchPin, INPUT); // Set pin 0 as an input
Serial.begin(9600); // Start serial communication at 9600 bps
if (digitalRead(switchPin) == HIGH) { // If switch is ON,
Serial.write(0); // send 1 to Processing
} else { // If the switch is not ON,
Serial.write(1); // send 0 to Processing
delay(100); // Wait 100 milliseconds
Processing:
import processing.video.*;
import processing.serial.*;
Serial port;
Movie myMovie;
int val = 0;
size(960, 540);
background(0);
myMovie = new Movie(this, "Video Dec 08, 19 20 04.mov");
myMovie.loop();
println(Serial.list());
// print a list of all available ports
port = new Serial(this, Serial.list()[1], 9600);
// choose the port to which the Arduino is connected
// on the PC this is usually COM1, on the Macintosh
// this is usually tty.usbserial-XXX
void draw() {
background(255);
if (0 < port.available()) {
val = port.read();
image(myMovie, 0, 0);
if (val == 0) {
myMovie.speed(1);
myMovie.speed(0);
// Called every time a new frame is available to read
void movieEvent(Movie m) {
m.read();
