I am trying to figure out a way to make 2 buttons work together in one code. I have no code so far since I don't know how I could do it.
By that I mean;
If button A is pressed, type letter "A"
If button B is pressed, type letter "B"
If both buttons A and B are pressed, type letter "C"
Is there a way to make this possible?
I am using an Arduino micro for the ones who would like to know.
I assume that the 2 buttons you refer to are connected to pins on the Arduino.
Have you looked at, tried and understood the Button example in the IDE ? Taking an input HIGH causes an LED to light but it could equally do something else
i have 2 basic pushbuttons connected to ground and digital pin 10 and digital pin 11.
the code i basicly use for pushbuttons is:
(i got this code from a friend of mine)
#include <Keyboard.h>
const byte switchPinA = 10;
const byte switchPinB = 11;
byte oldSwitchStateA = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateB = HIGH; // assume switch OFF because of pull-up resistor
const unsigned long debounceTime = 10; // milliseconds
pinMode (switchPinA, INPUT_PULLUP);
pinMode (switchPinB, INPUT_PULLUP);
byte switchStateA = digitalRead (switchPinA);
if (switchStateA != oldSwitchStateA)
oldSwitchStateA = switchStateA;
delay (debounceTime);
if (switchStateA == LOW)
Keyboard.press('a');
delay(10);
Keyboard.release('a');
byte switchStateB = digitalRead (switchPinB);
if (switchStateB != oldSwitchStateB)
oldSwitchStateB = switchStateB;
if (switchStateB == LOW)
Keyboard.press('b');
delay(10);
Keyboard.release('b');
but now i would like to combine 2 buttons to send out a different keyboard.press when both buttons are pressed
with the help of someone i managed to get it working,
the idea was that when button1 pressed, A happens, then if button1 is still pressed when button2 becomes pressed C goes not B.
with "A" goes i mean it sends out a keyboard.print("A")
by using a boolean flag called "oneButtonPressed" to signify that we're waiting for a second press after either button is pressed.
here is the new code
bool oneButtonPressed = false;
Serial.println("Press a button or two...");
if (switchStateA == LOW) //pressed
if (oneButtonPressed)
Serial.println("c");
Serial.println("a");
oneButtonPressed = true;
}// new press of A
if (switchStateA == HIGH) //release of A so cancel
Serial.println("b");
}// new press of B
if (switchStateB == HIGH) //release of B so cancel
