Hi, We are 3 students who have to make a buzz wire game for a project for our university. We are creating a buzz wire game, with a couple of extra adjustement. Like 2 moving servo's, a timer that shows how much time is left and a buzzer play a song, so it is working on your nerves.
So it includes a basic buzz wire game, with a theard and a stick. Two servo's are attached to the end of the wire, to create a random movent at random times. The first buzzer is too indicate you touched the thread, so it only has to make a short noise. The second buzzer is used to play a song while the game starts. The first led is to indicate the game is on, you do so by pressing on the first button. The second button is to start the game. When the game starts the song has to play, the timer has to start going off and the buzzer has to go of whenever you touch the wire.
And this is the set up in the arduino board
This is what we have so far, but is working far from perfect.
Serial.begin(9600); //Start verbinding met de pc
pinMode(deuntje, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
pinMode(timerled, OUTPUT);
pinMode(servo1, OUTPUT);
pinMode(servo2, OUTPUT);
pinMode(drukknop1, INPUT);
pinMode(drukknop2, INPUT);
pinMode(A3, INPUT_PULLUP);
// Led
pixels.begin(); // Start verbinding met de led (Dit heeft een vaste snelheid en moeten we dus niet opgeven)
pixels.clear(); // Zet alle leds uit
pixels.setBrightness(50); // Om uw ogen wat te besparen dimmen we de maximale helderheid van de leds
// Timerled
pixels1.begin(); // Start verbinding met de led (Dit heeft een vaste snelheid en moeten we dus niet opgeven)
pixels1.clear(); // Zet alle leds uit
pixels1.setBrightness(50); // Om uw ogen wat te besparen dimmen we de maximale helderheid van de leds
// Servomotor
servomotor1.attach(5); //Verbind de servomoter met pin 5
servomotor2.attach(3); //Verbind de servomoter met pin 3
//Aanzetten spel
while(digitalRead(drukknop1)== false){};
drukknop1waarde = digitalRead(drukknop1); // waarde drukknop om het spel aan te zetten wordt uitlezen
Serial.println(drukknop1waarde); // print waarde drukknop1
delay(100);
if (drukknop1waarde == 1 && druk_status == false) { // gaat het ledje aan oom aan te tonen dat het spel aan staat
//start
kleur = pixels.Color(0,255,0); //Maak een kleur aan en sla deze op in variabele kleur
pixels.setPixelColor(0, kleur); //Stuur deze kleur door naar de eerste led
pixels.show(); //Stuur signaal naar de led dat alle leds de kleur mogen tonen
delay(5);
druk_status = true;
} else if(drukknop1waarde == 1 && druk_status == true){
//stop
kleur = pixels.Color(0,0,0); //Maak een kleur aan en sla deze op in variabele kleur
pixels.clear();
pixels.show();
delay(5);
druk_status = false;
//Starten spel
while(digitalRead(drukknop2)== false){};
drukknop2waarde = digitalRead(drukknop2); // waarde drukknop om het spel te starten wordt uitlezen
Serial.println(drukknop2waarde); // print waarde drukknop2
delay(100);
if (drukknop2waarde == 1 && druk_status1 == false) { //Buzzer voor liedje gaat aan om aan te tonen dat het spel gestart is
//start
tone(buzzer, 1000);
druk_status1 = true;
} else if(drukknop2waarde == 1 && druk_status1 == true){
//stop
noTone(buzzer);
druk_status1 = false;
//At random bewegen servomtor1 op een random tijd
if (drukknop2waarde == 1 && druk_status == false) {
for (pos = 0; pos <= 180; pos += 180){
servomotor1.write(pos);
for (pos = 180; pos >= 0; pos -= 180){
delay(random(500, 5000));
}else if(drukknop2waarde == 1 && druk_status1 == true){
//stop
//At random bewegen servomto2 op een random tijd
servomotor2.write(pos);
//stop
//Timer
kleur1 = pixels1.Color(0,255,0);
pixels1.fill(kleur);
pixels1.show();
delay(1500);
for (int i=0; i < aantal_timerleds; i++) {
kleur1 = pixels1.Color(0,0,0); // Maak een kleur aan en sla deze op in variabele kleur
pixels1.setPixelColor(i, kleur1); // Stuur deze kleur door naar de eerste led
pixels1.show();
delay(1500);
Our questions now are:
- We have to replace the delay () with millis () but we are not sure how?
- We have to write a code so that the game only can start when start button is pushed.
- The game has to reset when the timer is done.
- When de start button is pushed in to set up the game and you want to shut off the game you have to push the button again, and than the hole game has to go out. But this isn't working either.
If you have other tips or tricks or know how to help us your more than welcome because we are really desprate.
Kind regards,
Three really stressed students that know very little about ardiuno
