I'm creating a project that uses Marc Boon's RFIDuino code for an SL018 reader.
I have several hundred RFID tags, each with various properties about its identity written to blocks on the card. I've written some test sketches that will run a variety of functions according to values that are read off these specific stored blocks. I'd like to run a couple of if loops that are true if a code/string read from the card matches a specific condition. I'm having trouble storing the values read off the card into an array which can then be tested in the for loops. The problem is my uneducated coding - I've given this a pretty damn hard try, and have finally given in to asking for help!
In the RFIDuino examples ("sl018demo"), line 239 calls up a function from SL018.cpp:
printArrayAscii(rfid.getBlock(), 16);
This outputs to the serial terminal a string of ASCII characters that are the human-readable code I'd like to test my if loops against. An example output for block 4 might be "PASTA". I'd ideally like something like:
if (storedBlock[4] == "PASTA" && storedBlock[5] == "ITALIAN") { // code here }
The printArrayAscii function is:
void printArrayAscii(byte array[], byte len)
for (byte i = 0; i < len;)
char c = array[i++];
if (c < 0x20 || c > 0x7e)
Serial.print('.');
Serial.print(char(c));
I'm trying to convert the byte array taken from the rfid.getBlock() into a variable string, rather than printed output. I tried modifying the printArrayAscii to output the ASCII to a char array instead, but I just can't get it to work. Help!
char* getString(byte array[], byte len)
char concatString[len];
for (byte i = 0; i < len;i++)
char c = array[i];
if (c <= 0x30 || c >= 0x39) // 0-9, only want numbers and letters
concatString[i] = char(c);
else if (c <= 0x41 || c >= 0x5a) // A-Z, only want numbers and letters (capitals)
concatString[i] = NULL;
//Serial.println(concatString);
return concatString;
If I uncomment "Serial.println(concatString);" and run getString(rfid.getBlock(), 16) in the sl018demo, I get the expected ASCII printed out. If I then comment the print command, and try "Serial.println(getString(rfid.getBlock(), 16));" in sl018 demo, I get gibberish. I've tried variations of the byte to char conversion, including:
char c = array[i];
char temp[ 2 ];
temp[ 0 ] = c;
temp[ 1 ] = '\0';
strcpy (concatString,temp);
I've also tried to make concatString[len] = '\0', which didn't help either.
I was hoping that this would be fairly simple. I essentially have an array of bytes, that I'd like to convert into an ASCII string. This works when Serial.print is used, but I'd like to store the output in a variable for later use (store each string in an array(i) (square brackets, else gives italics) where i corresponds to the block that that string was read from). I thought that my "return concatString" would give me a char array[len] that contained the byte-char transformed characters - but no go. That said, why does the Serial.println(concatString) work?
My ultimate outcome:
storedBlock[block] = getString(rfid.getBlock(), 16); // where getString... returns the string to be stored in storedBlock[block]
