C# and Arduino - Writting on LCD display full line char
Hi guys, im sorry for dropping in like this, im having a problem figuring out how to send a full line into LCD display, the current code i have only writes 1 char at once, actually i tried changing it to loop through every 16 position and write each letter, however it fades the previous letter and then writes the next, i wanted to display every word i typed for as long as the LCD can write it.
Here's my actual C# code: actual C# - Pastebin.com
and then there's the arduino code.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(16, 2);
  if(Serial.available())
    char c;
    c = Serial.read();
    for(int i = 0; i <1; i++){
    lcd.scrollDisplayRight();
    Serial.write(c);
    lcd.setCursor(i, 0);
    lcd.print(c);
      delay(2000);
         lcd.setCursor(0, 0);
         lcd.print("                                             ");
Do you want the received text to scroll or just to be displayed as static text ?
just static
OK.
Clear the LCD line, set the cursor position to the beginning of the line and set a counter to zero
When a character becomes available then read it and print it to the LCD and increment the counter.
Keep reading from Serial when a character is available and writing to the LCD.
When the counter reaches 16 stop reading Serial and wait a while
Start the process again
Note that the C# program sending the data must not close the serial connection or the Arduino will be reset.
Im not sure i was able to understand what you mean lol. Here's what i tried
  lcd.begin(16, 2);
    char c;
    int i;
    i = 0;
    while( i < 16){
    c = Serial.read();
    Serial.write(c);
    lcd.print(c);
    i++;
The current output plays out like this:
Can you please add that image as an attachment, per forum guidelines? Most people won't follow offsite links, especially when you don't bother to mark them with a URL tag.
aarg:
Fixed, sorry.
You are reading 16 characters but you don't know if 16 are available
Try this (untested)
byte counter = 0;
  lcd.begin(16, 2);
  if (Serial.available()) //only read when a character is available
    lcd.print(Serial.read());
    counter++;
  if (counter == 16)
    delay(5000);
    lcd.print("                ");
    counter = 0;
Awesome, exactly what i wanted. I just made some fixes since Serial.read() was sending text into bytes(numbers) to the lcd screen, all i did was store the reading into a char variable and works just as intended, thanks a lot!!!!!!!!!!!
here's the whole code
int counter = 0;
  lcd.begin(16, 2);
    char c = Serial.read();
    Serial.write(c);
    lcd.print(c);
    counter++;
  if (counter == 16)
    delay(5000);
    lcd.print("                ");
    counter = 0;
// CREDITS TO UKHeliBob
