C# communication help
Hey guys, I'm new here, just bought a couple of Arduino to play around with.
I'm a C# programmer at heart, so I'd like to learn how to use the Arduino with C# so I can write GUI programs and such for it.
My programming would be pretty simple. I saw a video on youtube a C# program controlling a couple LEDs... when you click on the program, it turns on the LEDs on the Arduino. Sounds simple... but how do I control the Arduino with C#????
The website for the project was no help since it was in Chinese... Anyhelp would be appreciated... or at least point me in the right direction. I've done quite a bit of searching and hasn't found much.
Hunt around for a C# serial library, then talk to Arduino over usb.
Here's a c++ example
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1159335334/4#4
You might be able to re write it for c#
Serial with C# is pretty easy. No need to hunt around for libraries -- .NET is already there!
using System.IO.Ports;
  // to open a port
  SerialPort port = new SerialPort("COM3", 9600, Parity.None, 8, StopBits.One);
  port.Open();
  // example: forever displaying incoming characters
  while (true)
    if (port.BytesToRead > 0)
      char c = (char)port.ReadByte();
      Console.Write(c);
  // example: writing a few bytes to the port
  byte[] arr = new byte[4];
  arr[0] = arr[1] = arr[2] = arr[3] = c;
  port.Write(arr, 0, 4); // write the 4 bytes
  // example: writing a string
  port.Write("Hello, world!");
Just look in the documentation for System.IO.Ports.SerialPort for more goodies.
Mikal
