My problem is that in C# i wrote a code to communicate with the COM 3 port, but when I type in a command using my C# code, my arduino is not doing what I want it to do.
My arduino is programed so that when the user types in 'H' the LED will turn on, and when the user types in 'B' the LED will blink. However instead of typing these commands through the arduino serial monitor i would like the commands to go through the c# program i wrote.
My code for the c# program is: using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms;
namespace Simple_Serial { public partial class Form1 : Form { // Add this variable
string RxString;
public Form1() { InitializeComponent(); }
private void button1_Click(object sender, EventArgs e) { serialPort1.PortName = "COM3"; serialPort1.BaudRate = 9600;
serialPort1.Open(); if (serialPort1.IsOpen) { buttonStart.Enabled = false; buttonStop.Enabled = true; textBox1.ReadOnly = false; }
private void buttonStop_Click(object sender, EventArgs e) { if (serialPort1.IsOpen) { serialPort1.Close(); buttonStart.Enabled = true; buttonStop.Enabled = false; textBox1.ReadOnly = true; } }
private void textBox1_KeyPress(object sender, KeyPressEventArgs e) { // If the port is closed, don't try to send a character.
if (!serialPort1.IsOpen) return;
// If the port is Open, declare a char[] array with one element. char[] buff = new char[1];
// Load element 0 with the key character.
buff[0] = e.KeyChar;
// Send the one character buffer. serialPort1.Write(buff, 0, 1);
// Set the KeyPress event as handled so the character won't // display locally. If you want it to display, omit the next line. e.Handled = true;
} private void DisplayText(object sender, EventArgs e) { textBox1.AppendText(RxString); }
private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { RxString = serialPort1.ReadExisting(); this.Invoke(new EventHandler(DisplayText));
private void Form1_FormClosing(object sender, FormClosingEventArgs e) { if (serialPort1.IsOpen) serialPort1.Close(); } } }
the following link has a picture of the gui i made for this code: http://picasaweb.google.com/116676369266478394688/SerialProgram#
can you tell me what the problem could possibly be?
Thanks!!
