hello i am trying to compile the following c++ code using the arduino ide 2.3.2. the error that i get is
cstdlib: no such file or directory. how do i include the listed libraries without having an indeterminate number of dependencies. thanks a lot.
# include <cstdlib>
# include <iostream>
# include <fstream>
# include <iomanip>
# include <cmath>
# include <ctime>
using namespace std;
int main ( );
double *lorenz_rhs ( double t, int m, double x[] );
double *r8vec_linspace_new ( int n, double a, double b );
double *rk4vec ( double t0, int n, double u0[], double dt,
double *f ( double t, int n, double u[] ) );
void timestamp ( );
//****************************************************************************80
int main ( )
// Purpose:
// MAIN is the main program for LORENZ_ODE.
// Discussion:
// Thanks to Ben Whitney for pointing out an error in specifying a loop,
// 24 May 2016.
// Licensing:
// This code is distributed under the MIT license.
// Modified:
// 24 May 2016
// Author:
// John Burkardt
string command_filename = "lorenz_ode_commands.txt";
ofstream command_unit;
string data_filename = "lorenz_ode_data.txt";
ofstream data_unit;
double dt;
int i;
int j;
int m = 3;
int n = 200000;
double *t;
double t_final;
double *x;
double *xnew;
timestamp ( );
cout << "\n";
cout << "LORENZ_ODE\n";
cout << " C++ version\n";
cout << " Compute solutions of the Lorenz system.\n";
cout << " Write data to a file for use by gnuplot.\n";
// Data
t_final = 40.0;
dt = t_final / ( double ) ( n );
// Store the initial conditions in entry 0.
t = r8vec_linspace_new ( n + 1, 0.0, t_final );
x = new double[m*(n+1)];
x[0+0*m] = 8.0;
x[0+1*m] = 1.0;
x[0+2*m] = 1.0;
// Compute the approximate solution at equally spaced times.
for ( j = 0; j < n; j++ )
xnew = rk4vec ( t[j], m, x+j*m, dt, lorenz_rhs );
for ( i = 0; i < m; i++ )
x[i+(j+1)*m] = xnew[i];
delete [] xnew;
// Create the plot data file.
data_unit.open ( data_filename.c_str ( ) );
for ( j = 0; j <= n; j = j + 50 )
data_unit << " " << setw(14) << t[j]
<< " " << setw(14) << x[0+j*m]
<< " " << setw(14) << x[1+j*m]
<< " " << setw(14) << x[2+j*m] << "\n";
data_unit.close ( );
cout << " Created data file \"" << data_filename << "\".\n";
Create the plot command file.
command_unit.open ( command_filename.c_str ( ) );
command_unit << "# " << command_filename << "\n";
command_unit << "#\n";
command_unit << "# Usage:\n";
command_unit << "# gnuplot < " << command_filename << "\n";
command_unit << "set term png\n";
command_unit << "set output 'xyz_time.png'\n";
command_unit << "set xlabel '<--- T --->'\n";
command_unit << "set ylabel '<--- X(T), Y(T), Z(T) --->'\n";
command_unit << "set title 'X, Y and Z versus Time'\n";
command_unit << "set grid\n";
command_unit << "set style data lines\n";
command_unit << "plot '" << data_filename
<< "' using 1:2 lw 3 linecolor rgb 'blue',";
command_unit << "'' using 1:3 lw 3 linecolor rgb 'red',";
command_unit << "'' using 1:4 lw 3 linecolor rgb 'green'\n";
command_unit << "set output 'xyz_3d.png'\n";
command_unit << "set xlabel '<--- X(T) --->'\n";
command_unit << "set ylabel '<--- Y(T) --->'\n";
command_unit << "set zlabel '<--- Z(T) --->'\n";
command_unit << "set title '(X(T),Y(T),Z(T)) trajectory'\n";
command_unit << "splot '" << data_filename
<< "' using 2:3:4 lw 1 linecolor rgb 'blue'\n";
command_unit << "quit\n";
command_unit.close ( );
cout << " Created command file '" << command_filename << "'\n";
// Terminate.
cout << "\n";
cout << "LORENZ_ODE:\n";
cout << " Normal end of execution.\n";
cout << "\n";
timestamp ( );
return 0;
// Purpose:
// LORENZ_RHS evaluates the right hand side of the Lorenz ODE.
// Licensing:
// Modified:
// 10 October 2013
// Author:
// John Burkardt
// Parameters:
// Input, double T, the value of the independent variable.
// Input, int M, the spatial dimension.
// Input, double X[M], the values of the dependent variables
// at time T.
// Output, double DXDT[M], the values of the derivatives
// of the dependent variables at time T.
double beta = 8.0 / 3.0;
double *dxdt;
double rho = 28.0;
double sigma = 10.0;
dxdt = new double[m];
dxdt[0] = sigma * ( x[1] - x[0] );
dxdt[1] = x[0] * ( rho - x[2] ) - x[1];
dxdt[2] = x[0] * x[1] - beta * x[2];
return dxdt;
double *r8vec_linspace_new ( int n, double a_first, double a_last )
// Purpose:
// R8VEC_LINSPACE_NEW creates a vector of linearly spaced values.
// Discussion:
// An R8VEC is a vector of R8's.
// 4 points evenly spaced between 0 and 12 will yield 0, 4, 8, 12.
// In other words, the interval is divided into N-1 even subintervals,
// and the endpoints of intervals are used as the points.
// Licensing:
// Modified:
// 29 March 2011
// Author:
// John Burkardt
// Parameters:
// Input, int N, the number of entries in the vector.
// Input, double A_FIRST, A_LAST, the first and last entries.
// Output, double R8VEC_LINSPACE_NEW[N], a vector of linearly spaced data.
double *a;
int i;
a = new double[n];
if ( n == 1 )
a[0] = ( a_first + a_last ) / 2.0;
for ( i = 0; i < n; i++ )
a[i] = ( ( double ) ( n - 1 - i ) * a_first
+ ( double ) ( i ) * a_last )
/ ( double ) ( n - 1 );
return a;
double *rk4vec ( double t0, int m, double u0[], double dt,
double *f ( double t, int m, double u[] ) )
// Purpose:
// RK4VEC takes one Runge-Kutta step for a vector ODE.
// Discussion:
// It is assumed that an initial value problem, of the form
// du/dt = f ( t, u )
// u(t0) = u0
// is being solved.
// If the user can supply current values of t, u, a stepsize dt, and a
// function to evaluate the derivative, this function can compute the
// fourth-order Runge Kutta estimate to the solution at time t+dt.
// Licensing:
// Modified:
// 09 October 2013
// Author:
// John Burkardt
// Parameters:
// Input, double T0, the current time.
// Input, double U0[M], the solution estimate at the current time.
// Input, double DT, the time step.
// Input, double *F ( double T, int M, double U[] ), a function which evaluates
// the derivative, or right hand side of the problem.
// Output, double RK4VEC[M], the fourth-order Runge-Kutta solution estimate
// at time T0+DT.
double *f0;
double *f1;
double *f2;
double *f3;
int i;
double t1;
double t2;
double t3;
double *u;
double *u1;
double *u2;
double *u3;
// Get four sample values of the derivative.
f0 = f ( t0, m, u0 );
t1 = t0 + dt / 2.0;
u1 = new double[m];
u1[i] = u0[i] + dt * f0[i] / 2.0;
f1 = f ( t1, m, u1 );
t2 = t0 + dt / 2.0;
u2 = new double[m];
u2[i] = u0[i] + dt * f1[i] / 2.0;
f2 = f ( t2, m, u2 );
t3 = t0 + dt;
u3 = new double[m];
u3[i] = u0[i] + dt * f2[i];
f3 = f ( t3, m, u3 );
// Combine them to estimate the solution.
u = new double[m];
u[i] = u0[i] + dt * ( f0[i] + 2.0 * f1[i] + 2.0 * f2[i] + f3[i] ) / 6.0;
// Free memory.
delete [] f0;
delete [] f1;
delete [] f2;
delete [] f3;
delete [] u1;
delete [] u2;
delete [] u3;
return u;
void timestamp ( )
// Purpose:
// TIMESTAMP prints the current YMDHMS date as a time stamp.
// Example:
// 31 May 2001 09:45:54 AM
// Licensing:
// Modified:
// 08 July 2009
// Author:
// John Burkardt
// Parameters:
// None
# define TIME_SIZE 40
static char time_buffer[TIME_SIZE];
const struct std::tm *tm_ptr;
std::time_t now;
now = std::time ( NULL );
tm_ptr = std::localtime ( &now );
std::strftime ( time_buffer, TIME_SIZE, "%d %B %Y %I:%M:%S %p", tm_ptr );
std::cout << time_buffer << "\n";
return;
# undef TIME_SIZE
