C++ STL for due?
Is there an STL implementation available for us on the Due?
I know that StandardCPlusPlus is out there for AVR users, and that uClibc++ is out there (with which would have no idea where to start).
Can someone point me in the right direction?
(This is one of the first google results when searching for arduino due and stl, and there is no answer?)
I tried the library GitHub - maniacbug/StandardCplusplus: Standard C++ for Arduino (port of uClibc++) which worked nicely for my purposed on mega2560, but on Due is does not compile.
First the compile complains about something which can be cured with -fpermissive in the boards file, but this leads to other errors...
In some threads I read that the use of STL is not recommended due to the very limited ram. But as far as I know vector is almost as memory economical as the usage of simple (static) fields for example. In my opinion a program with STL is much more readable and maintainable.
