i have searched everywhere looking for a Caesar cipher but i only found one or two for the Arduino so i created one using them as reference
I'm just listing it here for future arduino users with comments
i used a xbee pro for this coding and the coding is very compact
#include <SoftwareSerial.h>
SoftwareSerial zigBee(3,2);
char message; int cases = 0; int shift = 0; int choice = 0; char cases2;
{ // connecting to the serial monitour and zigbee
zigBee.begin(9600); Serial.begin(9600);
Serial.println(" "); Serial.println(" to transfer enter number 1"); Serial.println(" To receive enter number 2");
// check if anything is writen into the serial monitour
while (Serial.available()<=0){}
if (Serial.available()>=0){ choice = Serial.read();}}
void loop(){ // the tranismitting part of the caesaer cipher
if (choice==49) {// the number 1 in ascii format // making sure something is entered into the serial
Serial.println(" Please enter the amount of shifts between 1 and 25");
while (Serial.available()<=0){} // if the serial monitour
if (Serial.available()>=0){ shift = Serial.parseInt();
if (shift <26){
// makeing sure the shift amouint if less than 26 same as the aplpha bet
// print to the serial monitour and the zigbee with a delay to make sure the user has enough time to enter the shift amount
Serial.println(" shift amount accepted!"); Serial.print("the shift entered is: "); Serial.println(shift); zigBee.print(shift); delay(500);}
// if the shift amount is more than 25 than they will be mmet with an error message and loop back to the begining
else { Serial.println(" the amount of shifts entered is invalid"); delay(500); loop(); }}
// if the shift amount is correct than they can start to enter their message
Serial.println(" Enter Message");
while (Serial.available()>=0){ if (Serial.available()>0){ cases = Serial.read();
// the cases is red to make sure the letters entered is either upper case or lowercase using the ascii format 65 to upper case A
if (cases>='A' && cases<='Z' ){ // if ther cases are upper case then print them in both the serial monitour and the zigbee
cases-=65; message = (cases+shift)%26; message +=65; cases2=cases+65; Serial.print(message); zigBee.print(cases2); delay(1000); message = 0;
} // checking if the case is lower case and then printing them into the serial monitour abd zugbee
else if (cases>='a' && cases<='z'){ cases-=97; message = (cases+shift)%26; message +=97; cases2= cases +97;Serial.print(message); zigBee.print(cases2); delay(1000); message = 0; }
// if the letters is a symbol or number then print blank or space
else if (cases == ' ' ){ message= cases; Serial.print(message); zigBee.print(" "); delay(1000); message = 0;}}} }
// the recieving part of the caeser cipher
if (choice==50){ // the number 2 in ascii format
Serial.println(" conversion in progress");
// this part will check if anything was sent and check the shift amount and convert it into letters
while (zigBee.available()>=0){ if (zigBee.available()){ shift = zigBee.parseInt();
// if the shift amount was less than
if (shift<26){Serial.println(" conversion completed");
Serial.println(" Receiving shift amount to decrypt");
// is there something in the zigbee then read it and print it and if there isnt keep loopping
{ if (zigBee.available()) {cases2 = zigBee.read();Serial.print(cases2);}}}
else { loop();}}}}
else { Serial.println(" error only 1 or 2 are allowed to choose between reciever and transmiter"); delay(1000); setup(); }}
