Hi there.
I would like to implement a project in which I have three MPU6050 gyroscope sensors connected to a Teensy and I want the individual angles in the X, Y, and Z-axis as output.
Unfortunately I do not have much experience with the programming language and have found a code for oe sensor in the internet. I extended the Code to three senses.
#include<Wire.h>
const int MPU_addr1=0x68,MPU_addr2=0x69,MPU_addr3=0x68;
int16_t axis_X1,axis_Y1,axis_Z1;
int16_t axis_X2,axis_Y2,axis_Z2;
int16_t axis_X3,axis_Y3,axis_Z3;
int minVal=265;
int maxVal=402;
void setup(){
pinMode(taster1,INPUT);
pinMode(taster2,INPUT);
Wire.begin(); //begin the wire communication
Wire.beginTransmission(MPU_addr1); //begin, send the slave adress (in this case 68)
Wire.write(0x6B); //make the reset (place a 0 into the 6B register)
Wire.write(0);
Wire.endTransmission(true); //end the transmission
Wire.begin();
Wire.beginTransmission(MPU_addr2);
Wire.write(0x6B);
Wire.write(0);
Wire1.begin();
Wire1.beginTransmission(MPU_addr3);
Wire1.write(0x6B);
Wire1.write(0);
Wire1.endTransmission(true);
void loop(){
GetAngle1(MPU_addr1);
GetAngle2(MPU_addr2);
GetAngle3(MPU_addr3);
delay(50);
void GetAngle1(const int MPU) {
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr1,14,true);
axis_X1=Wire.read()<<8|Wire.read();
axis_Y1=Wire.read()<<8|Wire.read();
axis_Z1=Wire.read()<<8|Wire.read();
int xAng = map(axis_X1,minVal,maxVal,-90,90);
int yAng = map(axis_Y1,minVal,maxVal,-90,90);
int zAng = map(axis_Z1,minVal,maxVal,-90,90);
double x1= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
double y1= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
double z1= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print(x1);
Serial.print(",");
Serial.print(y1);
Serial.print(",");
Serial.print(z1);
Serial.print(",");
void GetAngle2(const int MPU) {
Wire.write(0x3B);
Wire.requestFrom(MPU_addr2,14,true);
axis_X2=Wire.read()<<8|Wire.read();
axis_Y2=Wire.read()<<8|Wire.read();
axis_Z2=Wire.read()<<8|Wire.read();
int xAng = map(axis_X2,minVal,maxVal,-90,90);
int yAng = map(axis_Y2,minVal,maxVal,-90,90);
int zAng = map(axis_Z2,minVal,maxVal,-90,90);
double x2= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
double y2= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
double z2= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print(x2);
Serial.print(",");
Serial.print(y2);
Serial.print(",");
Serial.print(z2);
Serial.print(",");
void GetAngle3(const int MPU) {
Wire1.write(0x3B);
Wire1.endTransmission(false);
Wire1.requestFrom(MPU_addr3,14,true);
axis_X3=Wire1.read()<<8|Wire1.read();
axis_Y3=Wire1.read()<<8|Wire1.read();
axis_Z3=Wire1.read()<<8|Wire1.read();
int xAng = map(axis_X3,minVal,maxVal,-90,90);
int yAng = map(axis_Y3,minVal,maxVal,-90,90);
int zAng = map(axis_Z3,minVal,maxVal,-90,90);
double x3= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
double y3= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
double z3= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print(x3);
Serial.print(",");
Serial.print(y3);
Serial.print(",");
Serial.println(z3);
Unfortunately, the second sensor only outputs the value 225 and the values for the x-axis for the other two sensors vary considerably. So, maybe someone can explain the Code, so that I may find the problem by myself. Or maybe someone of you has a better idea of how to read the angle.
I am thankful for any kind of help!
