I'm using the library (... \ Arduino \ hardware \ arduino \ sam \ system \ CMSIS \ CMSIS \ DSP_Lib \ Source \ StatisticsFunctions) to calculate the RMS value of the elements in the input vector. but the value I get is 0.0.
#define ARM_MATH_CM3
#include <arm_math.h>
float32_t data[5] = {1, 2, 3, 4, 5};
float32_t *d = data;
float32_t *pResult;
arm_rms_f32(d, 5, pResult);
while(1){
void arm_rms_f32(
float32_t * pSrc,
uint32_t blockSize,
float32_t * pResult)
float32_t sum = 0.0f; /* Accumulator */
float32_t in; /* Tempoprary variable to store input value */
uint32_t blkCnt; /* loop counter */
#ifndef ARM_MATH_CM0
/* Run the below code for Cortex-M4 and Cortex-M3 */
/* loop Unrolling */
blkCnt = blockSize >> 2u;
/* First part of the processing with loop unrolling. Compute 4 outputs at a time.
** a second loop below computes the remaining 1 to 3 samples. */
while(blkCnt > 0u)
/* C = A[0] * A[0] + A[1] * A[1] + A[2] * A[2] + ... + A[blockSize-1] * A[blockSize-1] */
/* Compute sum of the squares and then store the result in a temporary variable, sum */
in = *pSrc++;
sum += in * in;
in = *pSrc++;
sum += in * in;
in = *pSrc++;
sum += in * in;
in = *pSrc++;
sum += in * in;
/* Decrement the loop counter */
blkCnt--;
/* If the blockSize is not a multiple of 4, compute any remaining output samples here.
** No loop unrolling is used. */
blkCnt = blockSize % 0x4u;
#else
/* Run the below code for Cortex-M0 */
/* Loop over blockSize number of values */
blkCnt = blockSize;
#endif /* #ifndef ARM_MATH_CM0 */
while(blkCnt > 0u)
/* Compute sum of the squares and then store the results in a temporary variable, sum */
in = *pSrc++;
sum += in * in;
blkCnt--;
/* Compute Rms, store the result in the destination and print it */
Serial.println(sqrt(sum / (float32_t) blockSize));
