Calculating acceleration - Help
Hello there!
I am building a small robot and i have been doing some calculations regarding torque and what not and i just had a small query.
I am trying to find out the maximum acceleration of my robot.
I know that the resultant acceleration force is 1.53N and that the mass of my robot is 0.3kg.
So im using F=ma to calculate the acceleration in m/s^2 however when i rearrange i get the answer of 5.1m/s^2 , my doubt is that his seems extremely high for the size of my robot and motor.
The motor only has a torque of 0.06Nm. My powered wheel radius is 2cm.
I was just wondering if anyone could clarify for me if im doing something wrong or why the number seems so high...
Thank you!
That's not high. If the max speed were large it would be a safety issue but for a small slow
robot all it means is don't balance your drink on it!
To put it into realistic terms 5M/S^2 is around 0.5G, or half the force of gravity, so as MarkT says "not high"
A lot of the eventual force/torque will go into overcoming frictional elements also :drooling_face:
How did you measure the acceleration force?
Ideally, the motor should be able to accelerate the robot with 3 Newtons of force.
