called object is not a function or function pointer
In Windows 10 Pro, after recent updates were installed, I get the compile errors below. It worked fine, until about a week ago. It still compiles fine in my Win7 laptop, which has NOT installed any recent updates. Verbose output and sketches attached.
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c: In function 'analogRead':
wiring_analog.c:76:4: error: called object is not a function or function pointer
delayMicroseconds(10)
exit status 1
a1_KBMenu.ino (10.4 KB)
a2_tftMenu.ino (4.98 KB)
b_Chambers.ino (2.26 KB)
BAC_Main.ino (9.15 KB)
c_Pumps.ino (1.59 KB)
d_Measurements.ino (13.1 KB)
e_tftDisplay.ino (944 Bytes)
f_Touch.ino (1.44 KB)
p_Parameters.ino (4.42 KB)
y_Testing.ino (2.03 KB)
z_Functions01.ino (3.39 KB)
What did you change recently ?
Have you get the same version of the IDE on both PCs and are you compiling for the same target board ?
That's quite strange, considering that the current version of wiring_analog.c, which comes with Arduino IDE 1.8.9 does not make any calls to delayMicroseconds. Inside analogRead around the same line 76 it contains the following
	// without a delay, we seem to read from the wrong channel
	//delay(1);
but it is commented out anyway.
If you open the same wiring_analog.c file on your Win7 machine (the one that does not have this problem), do you see a call to delayMicroseconds in line 76?
Also, when GCC generates a "called object is not a function or function pointer" error, it usually supplements it with a "note: declared here" pointing out the location where the object in question was originally declared. Did you by any change see such note in your output?
