Select Tools=>Auto Format in the IDE and you'll notice that the function casting_forward() is indented, meaning that you're missing a curly brace somewhere (end of lopp(), I think).
Also you might want to include Wire.h.
Also I don't think this line will work:
if(command.equals(casting_forward("cf"))
since you're passing equals() something that's not a string, probably better to accept just "cf" from the serial monitor and compare to that.
Also casting_forward() expects to be called with two floats and you're calling it with no arguments.
///all functions code//
//setup tic
#include <Tic.h>
TicI2C tic;
//encoder setup
// setup encoder libraries and variables
#include <SPI.h>
#define CS 3 //Chip or Slave select
uint16_t ABSposition = 0;
uint16_t ABSposition_last = 0;
uint8_t temp[2]; //This one.
float deg = 0.00;
float tempDeg;
char x;
//wiper bounds in degrees
float home1 = 180.00;
float stop1 = 240.00;
float stop2 = 120.00;
//serial monitor setup
String command;
///void setup setup section
///tic setup
// Set up I2C.
Wire.begin();
// Give the Tic some time to start up.
delay(20);
// Set the Tic's current position to 0, so that when we command
// it to move later, it will move a predictable amount.
tic.haltAndSetPosition(0);
// Tells the Tic that it is OK to start driving the motor. The
// Tic's safe-start feature helps avoid unexpected, accidental
// movement of the motor: if an error happens, the Tic will not
// drive the motor again until it receives the Exit Safe Start
// command. The safe-start feature can be disbled in the Tic
// Control Center.
tic.exitSafeStart();
//encoder setup
Serial.begin(250000);
pinMode(CS,OUTPUT);//Slave Select
digitalWrite(CS,HIGH);
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV32);
Serial.println("starting");
Serial.flush();
delay(2000);
SPI.end();
//dc motor setup
pinMode(8, OUTPUT); //set direction pin as output, dir
pinMode(11, OUTPUT); //set enable pin as output, pwm
//serial input command setup 11-4-9:31pm
// Sends a "Reset command timeout" command to the Tic. We must
// call this at least once per second, or else a command timeout
// error will happen. The Tic's default command timeout period
// is 1000 ms, but it can be changed or disabled in the Tic
// Control Center.
void resetCommandTimeout()
tic.resetCommandTimeout();
// Delays for the specified number of milliseconds while
// resetting the Tic's command timeout so that its movement does
// not get interrupted by errors.
void delayWhileResettingCommandTimeout(uint32_t ms)
uint32_t start = millis();
do
} while ((uint32_t)(millis() - start) <= ms);
// Polls the Tic, waiting for it to reach the specified target
// position. Note that if the Tic detects an error, the Tic will
// probably go into safe-start mode and never reach its target
// position, so this function will loop infinitely. If that
// happens, you will need to reset your Arduino.
void waitForPosition(int32_t targetPosition)
do
} while (tic.getCurrentPosition() != targetPosition);
// more encoder setup
uint8_t SPI_T (uint8_t msg) //Repetive SPI transmit sequence
uint8_t msg_temp = 0; //vairable to hold recieved data
digitalWrite(CS,LOW); //select spi device
msg_temp = SPI.transfer(msg); //send and recieve
digitalWrite(CS,HIGH); //deselect spi device
return(msg_temp); //return recieved byte
/////call functions void loop
void loop(){
uint8_t recieved = 0xA5; //just a temp vairable
ABSposition = 0; //reset position vairable
SPI.begin(); //start transmition
SPI_T(0x10); //issue read command
recieved = SPI_T(0x00); //issue NOP to check if encoder is ready to send
while (recieved != 0x10) //loop while encoder is not ready to send
recieved = SPI_T(0x00); //cleck again if encoder is still working
delay(2); //wait a bit
temp[0] = SPI_T(0x00); //Recieve MSB
temp[1] = SPI_T(0x00); // recieve LSB
digitalWrite(CS,HIGH); //just to make sure
SPI.end(); //end transmition
temp[0] &=~ 0xF0; //mask out the first 4 bits
ABSposition = temp[0] << 8; //shift MSB to correct ABSposition in ABSposition message
ABSposition += temp[1]; // add LSB to ABSposition message to complete message
if (ABSposition != ABSposition_last) //if nothing has changed dont wast time sending position
ABSposition_last = ABSposition; //set last position to current position
deg = ABSposition;
deg = deg * 0.08789;// aprox 360/4096
Serial.println(deg); //send position in degrees
//Serial.println(encoder_read); //send position in degrees
return(deg);
delay(10); //wait a bit till next check
///serial input void loop section 11-4-9:01pm
if(Serial.available()){
command = Serial.readStringUntil('\n');
if(command.equals(casting_forward("cf")){
casting_forward();
else if(command.equals(casting_backward("cb")){
casting_backward();
else if(command.equals(home_flick_rod("hr")){
home_flick_rod();
else if(command.equals(line_flick_backward("lb")){
line_flick_backward();
else if(command.equals(line_flick_forward("lf")){
line_flick_forward();
else if(command.equals(carriage_forward_flick("cg")){
carriage_forward_flick();
//////functions
//////carriage_forward_flick function
void carriage_forward_flick(){
// Tell the Tic to move to position 10000, and wait until it gets
// there.
tic.setTargetVelocity(25000); //motor vel in 10000 pulses per second
tic.setTargetPosition(10000);// in steps
waitForPosition(1000);//ms
//////carriage_backward_flick function
void carriage_backward_flick(){
// Tell the Tic to move to position -10000, and wait until it gets
// there.
tic.setTargetPosition(-10000);// in steps
return;
//////function for home flick
void home_flick_rod(float home1,float encoder, float stop1, float stop2) {
Serial.println("end home flick");
if (encoder > home1){
digitalWrite (8,HIGH); //dir cw low ccw
analogWrite (11,30);}
else { digitalWrite (8,LOW);
if (abs(encoder - home1) < 5){
analogWrite (11,0);}
return;
Serial.println("at home");
Serial.read();
///////function for rod_forward_flick
void rod_forward_flick(float stop1,float deg) {
//Serial.println("end forward flick");
digitalWrite (8,LOW); //dir cw low ccw
if (deg < stop1){
else {
return;
//////functon for rod_back_flick
void rod_back_flick(float stop2,float deg) {
//Serial.println("end backward flick");
if (deg > stop2){
else {
return;
//11-4-8:35pm
//////function for casting rod forward
void casting_forward(float stop2, float deg){
for (int i = 0; 6; i++)
rod_forward_flick(stop2, deg);
delay(10);
delay(10);
return;
//////function for casting rod backward
void casting_backward(float stop1, float deg){
rod_back_flick(stop1, deg);
delay(10);
carriage_backward_flick();
delay(10);
return;
/////function for flicking rod forward (flick line out)
void line_flick_forward(float stop2, float deg){
delay(10);
delay(10);
return;
/////function for flicking rod backward (flick line back)
void line_flick_backward(float stop1, float deg){
delay(10);
delay(10);
return;
