Camera (still images) protocols/hardware advise
Hello,
Any ideas on connecting a camera (which?) to an ESP32 via long cable? How it is usually done? What cameras are popular for this? What protocols used to transmit pictures from the camera?
What I need is to make a picture once a hour, low resolution, and transmit it over the 22m cable to my ESP32 board.
Any opinions/ideas/links are welcome :). This is for a seawater monitoring (particles, silt, mud). There is a static flat underwater object (a white and black board) which is located 2m away from the camera. What I need - is to take a picture of this b/w board and send it to the mainland via cable link.
Thanks
Not sure why you chose an ESP32 for. 22m is quite a way for a camera cable. Maybe consider a USB camera, and appropriate hardware to work with it.
For that low data rate, you can use an ESP32-CAM to take the picture and then sent it elsewhere via UART serial over the 22 m cable.
There are also camera modules with a serial connection.
So, you are looking for a ESP32 camera connector that is 22m long?
Camera, connector, protocol to transmit a JPEG over 22m link. Now looking into ESP32Cam. It has an UART which I can run over rs485 so will probably fit my needs.
I have used this code to take gray scale snapshots and send the raw image data over UART serial to a PC. It may require minor modifications as the default ESP32-CAM libraries were recently updated. Or use older versions of the libraries.
For long serial cables, test with much lower serial data rates and work up.
// from https://github.com/alanesq/esp32cam-demo/blob/master/Misc/esp32camdemo-greyscale.ino
#if !defined ESP32
#error This sketch is only for an ESP32Cam module
#endif
#include "esp_camera.h"       // https://github.com/espressif/esp32-camera
// #include "camera_pins.h"
//                           -SETTINGS
const char* stitle = "ESP32Cam-demo-gs";               // title of this sketch
const char* sversion = "10Jul21";                      // Sketch version
// Camera related
const bool flashRequired = 1;                        // If flash to be used when capturing image (1 = yes)
const framesize_t FRAME_SIZE_IMAGE = FRAMESIZE_UXGA;
// Image resolution:
//               default = "const framesize_t FRAME_SIZE_IMAGE = FRAMESIZE_VGA"
//               160x120 (QQVGA), 128x160 (QQVGA2), 176x144 (QCIF), 240x176 (HQVGA),
//               320x240 (QVGA), 400x296 (CIF), 640x480 (VGA, default), 800x600 (SVGA),
//               1024x768 (XGA), 1280x1024 (SXGA), 1600x1200 (UXGA)
#define PIXFORMAT PIXFORMAT_GRAYSCALE;               // image format, Options =  YUV422, GRAYSCALE, RGB565, JPEG, RGB888
#define WIDTH 1600                                    // image size
#define HEIGHT 1200
int cameraImageExposure = 0;                         // Camera exposure (0 - 1200)   If gain and exposure both set to zero then auto adjust is enabled
int cameraImageGain = 0;                             // Image gain (0 - 30)
const int TimeBetweenStatus = 600;                     // speed of flashing system running ok status light (milliseconds)
const int indicatorLED = 33;                           // onboard small LED pin (33)
const int brightLED = 4;                               // onboard Illumination/flash LED pin (4)
const int iopinA = 13;                                 // general io pin 13
const int iopinB = 12;                                 // general io pin 12 (must not be high at boot)
const int iopinC = 16;                                 // input only pin 16 (used by PSRam but you may get away with using it for a button)
const int serialSpeed = 115200;                        // Serial data speed to use
// camera settings (for the standard - OV2640 - CAMERA_MODEL_AI_THINKER)
// see: https://randomnerdtutorials.com/esp32-cam-camera-pin-gpios/
// set camera resolution etc. in 'initialiseCamera()' and 'cameraImageSettings()'
#define CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32      // power to camera (on/off)
#define RESET_GPIO_NUM    -1      // -1 = not used
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26      // i2c sda
#define SIOC_GPIO_NUM     27      // i2c scl
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25      // vsync_pin
#define HREF_GPIO_NUM     23      // href_pin
#define PCLK_GPIO_NUM     22      // pixel_clock_pin
#include "driver/ledc.h"      // used to configure pwm on illumination led
// Used to disable brownout detection
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
// sd-card
#include "SD_MMC.h"                         // sd card - see https://randomnerdtutorials.com/esp32-cam-take-photo-save-microsd-card/
#include <SPI.h>
#include <FS.h>                             // gives file access
#define SD_CS 5                             // sd chip select pin = 5
// Define some global variables:
uint32_t lastStatus = millis();           // last time status light changed status (to flash all ok led)
uint32_t lastCamera = millis();           // timer for periodic image capture
bool sdcardPresent;                       // flag if an sd card is detected
int imageCounter;                         // image file name on sd card counter
uint32_t illuminationLEDstatus;           // current brightness setting of the illumination led
  Serial.begin(serialSpeed);                     // Start serial communication
  Serial.println("\n");                      // line feeds
  Serial.printf("Starting - %s - %s \n", stitle, sversion);
  // Serial.print("Reset reason: " + ESP.getResetReason());
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);     // Turn-off the 'brownout detector'
  // small indicator led on rear of esp32cam board
  pinMode(indicatorLED, OUTPUT);
  digitalWrite(indicatorLED, LOW);              // small indicator led on
  digitalWrite(indicatorLED, HIGH);             // small indicator led off
  // set up camera
  Serial.print(("\nInitialising camera: "));
  if (initialiseCamera()) {
    Serial.println("OK");
  else {
    Serial.println("Error!");
  // define i/o pins
  pinMode(indicatorLED, OUTPUT);            // defined again as sd card config can reset it
  digitalWrite(indicatorLED, HIGH);         // led off = High
  pinMode(iopinA, OUTPUT);                  // pin 13 - free io pin, can be used for input or output
  pinMode(iopinB, OUTPUT);                  // pin 12 - free io pin, can be used for input or output (must not be high at boot)
  pinMode(iopinC, INPUT);                   // pin 16 - free input only pin
  // startup complete
  Serial.println("\nSetup complete...");
}  // setup
  //  //  demo to Capture an image
  if ( (unsigned long)(millis() - lastCamera) >= 10000UL) { // ever 10 sec
    lastCamera = millis();     // reset timer
    capture_still();              // collect and send image out serial port
  // flash status LED to show sketch is running ok
  if ((unsigned long)(millis() - lastStatus) >= TimeBetweenStatus) {
    lastStatus = millis();                                               // reset timer
    digitalWrite(indicatorLED, !digitalRead(indicatorLED));              // flip indicator led status
}  // loop
//                        Initialise the camera
// returns TRUE if successful
bool initialiseCamera() {
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;               // XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
  config.pixel_format = PIXFORMAT;              // Options =  YUV422, GRAYSCALE, RGB565, JPEG, RGB888
  config.frame_size = FRAME_SIZE_IMAGE;         // Image sizes: 160x120 (QQVGA), 128x160 (QQVGA2), 176x144 (QCIF), 240x176 (HQVGA), 320x240 (QVGA),
  //              400x296 (CIF), 640x480 (VGA, default), 800x600 (SVGA), 1024x768 (XGA), 1280x1024 (SXGA),
  //              1600x1200 (UXGA)
  config.jpeg_quality = 10;                     // 0-63 lower number means higher quality
  config.fb_count = 1;                          // if more than one, i2s runs in continuous mode. Use only with JPEG
  // check the esp32cam board has a psram chip installed (extra memory used for storing captured images)
  //    Note: if not using "AI thinker esp32 cam" in the Arduino IDE, PSRAM must be enabled
  if (!psramFound()) {
    Serial.println("Warning: No PSRam found so defaulting to image size 'CIF'");
    config.frame_size = FRAMESIZE_CIF;
  //#if defined(CAMERA_MODEL_ESP_EYE)
  //  pinMode(13, INPUT_PULLUP);
  //  pinMode(14, INPUT_PULLUP);
  //#endif
  esp_err_t camerr = esp_camera_init(&config);  // initialise the camera
  if (camerr != ESP_OK) {
    Serial.printf("ERROR: Camera init failed with error 0x%x", camerr);
  cameraImageSettings();                        // apply custom camera settings
  return (camerr == ESP_OK);                    // return boolean result of camera initialisation
//                   -Change camera image settings
// Adjust image properties (brightness etc.)
// Defaults to auto adjustments if exposure and gain are both set to zero
// - Returns TRUE if successful
// BTW - some interesting info on exposure times here: https://github.com/raduprv/esp32-cam_ov2640-timelapse
bool cameraImageSettings() {
  sensor_t *s = esp_camera_sensor_get();
  // something to try?:     if (s->id.PID == OV3660_PID)
  if (s == NULL) {
    Serial.println("Error: problem reading camera sensor settings");
    return 0;
  // if both set to zero enable auto adjust
  if (cameraImageExposure == 0 && cameraImageGain == 0) {
    // enable auto adjust
    s->set_gain_ctrl(s, 1);                       // auto gain on
    s->set_exposure_ctrl(s, 1);                   // auto exposure on
    s->set_awb_gain(s, 1);                        // Auto White Balance enable (0 or 1)
    // Apply manual settings
    s->set_gain_ctrl(s, 0);                       // auto gain off
    s->set_exposure_ctrl(s, 0);                   // auto exposure off
    s->set_agc_gain(s, cameraImageGain);          // set gain manually (0 - 30)
    s->set_aec_value(s, cameraImageExposure);     // set exposure manually  (0-1200)
  return 1;
}  // cameraImageSettings
//    // More camera settings available:
//    // If you enable gain_ctrl or exposure_ctrl it will prevent a lot of the other settings having any effect
//    // more info on settings here: https://randomnerdtutorials.com/esp32-cam-ov2640-camera-settings/
//    s->set_gain_ctrl(s, 0);                       // auto gain off (1 or 0)
//    s->set_exposure_ctrl(s, 0);                   // auto exposure off (1 or 0)
//    s->set_agc_gain(s, cameraImageGain);          // set gain manually (0 - 30)
//    s->set_aec_value(s, cameraImageExposure);     // set exposure manually  (0-1200)
//    s->set_vflip(s, cameraImageInvert);           // Invert image (0 or 1)
//    s->set_quality(s, 10);                        // (0 - 63)
//    s->set_gainceiling(s, GAINCEILING_32X);       // Image gain (GAINCEILING_x2, x4, x8, x16, x32, x64 or x128)
//    s->set_brightness(s, cameraImageBrightness);  // (-2 to 2) - set brightness
//    s->set_lenc(s, 1);                            // lens correction? (1 or 0)
//    s->set_saturation(s, 0);                      // (-2 to 2)
//    s->set_contrast(s, cameraImageContrast);      // (-2 to 2)
//    s->set_sharpness(s, 0);                       // (-2 to 2)
//    s->set_hmirror(s, 0);                         // (0 or 1) flip horizontally
//    s->set_colorbar(s, 0);                        // (0 or 1) - show a testcard
//    s->set_special_effect(s, 0);                  // (0 to 6?) apply special effect
//    s->set_whitebal(s, 0);                        // white balance enable (0 or 1)
//    s->set_awb_gain(s, 1);                        // Auto White Balance enable (0 or 1)
//    s->set_wb_mode(s, 0);                         // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
//    s->set_dcw(s, 0);                             // downsize enable? (1 or 0)?
//    s->set_raw_gma(s, 1);                         // (1 or 0)
//    s->set_aec2(s, 0);                            // automatic exposure sensor?  (0 or 1)
//    s->set_ae_level(s, 0);                        // auto exposure levels (-2 to 2)
//    s->set_bpc(s, 0);                             // black pixel correction
//    s->set_wpc(s, 0);                             // white pixel correction
//      -access image as greyscale data - i.e. http://x.x.x.x/
bool capture_still() {
  uint16_t x, y;
  Serial.print("***** greyscale image dump\n");
  camera_fb_t *frame = esp_camera_fb_get();
  if (!frame)
    return false;
  int npix=0;
  // for each pixel in image
  for (size_t i = 0; i < frame->len; i++) {
    x = i % WIDTH;                   // x position in image
    y = floor(i / WIDTH);            // y position in image
    byte pixel = frame->buf[i];                     // pixel value
    // show data
   Serial.print((unsigned int)pixel);
   Serial.print("\n");
    npix++;
  Serial.print("***** ");  //separator
  Serial.print(npix);
  Serial.print(" data lines\n");
  esp_camera_fb_return(frame);                      // return storage space
  return true;
Thank you for sharing!
Did you use some sort of flow control here? I am worring about buffer overruns on the receiving side. Or it is not an issue?
ESP32Cam UART (null modem) --> RS485 Converter -->.........shielded twisted pair.....->RS485 converter-->ESP32 UART
Not an issue on the PC! Let us know if it works on ESP32.
