can 2 interupt put in same pin?
hi, sorry for my bad english,
i test this code from internet
const byte interruptPin = 19;
volatile byte state = LOW;
   pinMode(LED_BUILTIN, OUTPUT);
   pinMode(interruptPin, INPUT_PULLUP);
   attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
   digitalWrite(LED_BUILTIN, state);
void blink() {
   state = !state;
after test it, it seems interesting, i study it, and edit it to become like this:
  attachInterrupt(digitalPinToInterrupt(interruptPin),blinkOn, RISING);
  attachInterrupt(digitalPinToInterrupt(interruptPin),blinkOff, FALLING);
void blinkOn() {
state = HIGH;
void blinkOff(){
state = LOW;
when the arduino turned on, the build-in led is on,
then when first contact, the build-in is turned off,
but when i put the contact, the build-in is not back to on,
it seems 2 interrupt cant be place in same pin, or my code is wrong,
i will appeciate any guide , thanks
That is true.
If you want both the RISING edge and the FALLING edge to trigger different functions, use CHANGE and ONE interrupt handler. In the interrupt handler, determine the current state of the pin. If it is now HIGH, the rising edge triggered the interrupt handler. If it is now LOW, the falling edge triggered the interrupt handler. Take the appropriate action.
PaulS:
That is true.
ah thank a lot, it nice if my guess is right
