Hi All, i am new to arudino, Trying to run a program, but its shows debugging not supported by arudino uno, in my code i dont have any debug command. can any on help how disable the debugger.i am using arudino uno.
Thanks in Advance
Thanks in Advance
Welcome to the forum
Which version of the IDE are you using ?
How are you trying to upload your sketch ?
Clicking the wrong button in the toolbar? I assume that you're using IDE 2.x (please confirm as you posted this in the IDE 1.x section) and there are three buttons.
For an upload, you need the one in the center.
That is my assumption too, hence my questions
Hi ,
I am using IDE 2, Able to upload now. I thought to run the program i need to use the run button, But its running after upload
Thanks for your help @sterretje @UKHeliBob.
Topic moved to the correct section of the forum.
