I dont know how to sent bitmap via xbee. At the moment I can only sent bits. Please give me some advise.
What I really want is to receive bitmap form xbee then display it on the Epaper display. I assume that the bitmap have to be store in RAM first.
A cursory look suggests that under the hood, that library sends images line by line. You could probably build something around the EPD_Class::line function that does away with the need to hold all the image data - just send each line as you get it from the xBee.
Are you using a PC to send the bitmap and if so do you have the software in place for sending from that?
I would suggest that you start by sorting out the hardware, select devices that will co-exist happily, if you use I2C or SPI you can put multiple devices onto a single bus, which helps.
Why do you want to store the bitmap as a text file?
38KB
[/quote]
Well, it would help you to understand the bitmap format that the E-Ink display wants. According to their documentation it is xbm format. I saved a sample image out of gimp to xbm (found there is regular and X10 format, check with the panel people to see which version is preferred), and found that xbm is an ASCII encoded bitmap. Because the images will be larger than the memory available on most Arduino boards, you should look into any one of the many SD card shields to use the SD card as external (and non-volatile) memory.
My suggestion for your learning process:
First work with learning how to write and read files on a SD card.
Learn how to transmit ASCII files over xbee and save them to a SD card.
Learn how to read a file and send it to the E-Ink display.
Figure out how to connect both the SD shield and the E-Ink display simultaneously to your Arduino. (Note: you may have to get creative with pins for the SPI interface. Both can (and should) share the MOSI, MISO, and SCK pins, but each should have separate CS/SSEL pins. If any of this note doesn't make sense to you, reasearch SPI interfaces.)
Use what you have learned from the above steps to build your master plan. Muahahaha!
