I want to display some data from my car with the help of arduino. I selected 9 random data for now and I want to add more in the future.
I was able to receive data, but it does not come sequentially and quickly.I would appreciate if you share your suggestions with me on how to improve my coding.
And I have an idea to update the primary data more often for example car speed and engine speed are less priority I don't know where to start on this issue.
I would appreciate it if you could share your suggestions about how I should proceed in this regard.
My code;
#include <mcp_can.h>
#include <SPI.h>
#define LISTEN_ID 0x7EA
#define REPLY_ID 0x7E0
#define FUNCTIONAL_ID 0x7DF
// CAN TX Variables
unsigned long prevTx = 0;
unsigned int invlTx = 100;
byte pidarray[9] = {0x05,0x0B,0x0C,0x0D,0x0F,0x11,0x5C,0x5D,0x5E};
int Engine_Coolant_Temp,Intake_Pressure,Engine_RPM,Vehicle_Speed,IAT,Throttle_Position,Engine_Oil_Temp,Fuel_Injection_Timing,Engine_Fuel_Rate;
// CAN RX Variables
unsigned long rxID;
byte dlc;
byte rxBuf[8];
char msgString[128]; // Array to store serial string
// CAN Interrupt and Chip Select Pins
#define CAN0_INT 7
MCP_CAN CAN0(17);
void setup(){
while(!Serial);
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_STDEXT, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
else{
Serial.println("Error Initializing MCP2515... Permanent failure! Check your code & connections");
while(1);
// Standard ID Filters
CAN0.init_Mask(0,0x7F00000); // Init first mask...
CAN0.init_Filt(0,0x7DF0000); // Init first filter...
CAN0.init_Filt(1,0x7E10000); // Init second filter...
CAN0.init_Mask(1,0x7F00000); // Init second mask...
CAN0.init_Filt(2,0x7DF0000); // Init third filter...
CAN0.init_Filt(3,0x7E10000); // Init fourth filter...
CAN0.init_Filt(4,0x7DF0000); // Init fifth filter...
CAN0.init_Filt(5,0x7E10000); // Init sixth filter...
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
void loop(){
if(!digitalRead(CAN0_INT)){ // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxID, &dlc, rxBuf); // Get CAN data
if((rxID & 0x41000000) == 0x41000000){ // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
Serial.print(msgString);
if (rxBuf[2]==0x05) {
Engine_Coolant_Temp = rxBuf[3]-40;
Serial.print("Engine_Coolant_Temp:");
Serial.println(Engine_Coolant_Temp);
else if (rxBuf[2]==0x0B) {
Intake_Pressure = rxBuf[3];
Serial.print("Intake_Pressure:");
Serial.println(Intake_Pressure);
else if (rxBuf[2]==0x0C) {
Engine_RPM = (256*rxBuf[3]+rxBuf[4])/4;
Serial.print("Engine_RPM:");
Serial.println(Engine_RPM);
else if (rxBuf[2]==0x0D) {
Vehicle_Speed = rxBuf[3];
Serial.print("Vehicle_Speed:");
Serial.println(Vehicle_Speed);
else if (rxBuf[2]==0x0F) {
IAT = rxBuf[3]-40;
Serial.print("IAT:");
Serial.println(IAT);
else if (rxBuf[2]==0x11) {
Throttle_Position = (100/255)*rxBuf[3];
Serial.print("Throttle_Position:");
Serial.println(Throttle_Position);
else if (rxBuf[2]==0x5c) {
Engine_Oil_Temp = rxBuf[3]-40;
Serial.print("Engine_Oil_Temp:");
Serial.println(Engine_Oil_Temp);
else if (rxBuf[2]==0x5D) {
Fuel_Injection_Timing = (((256*rxBuf[3])+rxBuf[4])/128)-210;
Serial.print("Fuel_Injection_Timing:");
Serial.println(Fuel_Injection_Timing);
else if (rxBuf[2]==0x5E) {
Engine_Fuel_Rate = (((256*rxBuf[3])+rxBuf[4])/20);
Serial.print("Engine_Fuel_Rate:");
Serial.println(Engine_Fuel_Rate);
for (int b = 0; b < 9 ; b++)
char pid;
if (b==0) {
pid=pidarray[0];
} else if (b==1) {
pid=pidarray[1];
else if (b==2) {
pid=pidarray[2];
else if (b==3) {
pid=pidarray[3];
else if (b==4) {
pid=pidarray[4];
else if (b==5) {
pid=pidarray[5];
else if (b==6) {
pid=pidarray[6];
else if (b==7) {
pid=pidarray[7];
else if (b==8) {
pid=pidarray[8];
char tmp[8] = {0x02, 0x01, pid, 0, 0, 0, 0, 0};
if((millis() - prevTx) >= invlTx){
prevTx = millis();
if(CAN0.sendMsgBuf(FUNCTIONAL_ID,0, 8, tmp) == CAN_OK){
Serial.print("Message Sent Successfully! b:" );
Serial.println(b);
Serial.println("Error Sending Message...");
Serial monitor result;
