Can=Bus Shield V2 By Seed Studio
Hi, I'm new to this and I wanted some help with a question about Can Bus Shield...
I have some calibration equipment, which has an arduino and a Can-Bus Shield, which has been the V1.2 of Seed Studio, but it was damaged in one of my equipment, I couldn't get it to change it, instead I got the Can-Bus Shield V2 By Seed Studio, which by the pin distribution I thought was the same, The Arduino I'm using is the Arduino UNO.
The problem is that I already changed the Can-Bus Shield and I get an error:
Enter setting mode fail
CAN BUS Shield init fail
Init CAN BUS Shield again
That error keeps coming up and coming out, I thought that the Bus Can Shield had to be programmed separately, but as I understood it, it should not be programmed, I thought that the Can Bus Shield that I bought would have been defective or that it would have been damaged, but I bought another and I still have Same problem, I already exchanged with the Bus Can Shield V1.2 By Seed Studio from my other equipment and the Arduino works without any problem...
I really don't know about Can Bus Shield, if someone could support me I would greatly appreciate it.
This is the Can Bus Shield that I got
And this is the one It should wear
CS pin on v 1.2 is pin 9 and the newer ones is pin 10 ?? maybe double check the CS pin in the code and compare to the version of board.
good luck,
clint
