This topic is not a question but a sharing to those who are wondering about this. I did a test and the answer is yes to all four pins. However, I didn't test for the interrupt function. The circuit is connected from each pin to the ground and the pins used an internal pull-up function.
DigitalReadSerial
Reads a digital input on pin 2, prints the result to the Serial Monitor
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/DigitalReadSerial
// digital pin 2 has a pushbutton attached to it. Give it a name:
int pushButton = 69;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// make the pushbutton's pin an input:
pinMode(pushButton, INPUT);
digitalWrite(pushButton, HIGH);
// the loop routine runs over and over again forever:
// read the input pin:
int buttonState = digitalRead(pushButton);
// print out the state of the button:
Serial.println(buttonState);
delay(1000); // delay in between reads for stability
