can i declare a string array, without knowing exactly the number of array?
I am trying to write a function that stores all my filenames inside an array of strings.
basically will use a while loop, then retrieve the filenames, but i do not know before hand how many arrays of the string i should require before hand.
Is there a way to create a string array without knowing how many beforehand? or are there workarounds? open to suggestions. thanks :slight_smile:
im using sdfat library.
  numFiles = 0;
  sd.vwd()->rewind();
  while (file.openNext(sd.vwd(), O_READ)) {
    String filename[numFiles] = file.printName(&Serial);
    numFiles ++;
    file.close();
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
And when you compile the program you will need to allocate the full amount of space you need.
...R
Remind us about the constraints on filenames.
