Can I include a header file that is not a library?
I am transitioning from programming AVR chips in C to using an Arduino platform. I used to include header files with the following syntax:
#include "file.h"
instead of a library which would be:
#include <library.h>
If I was just including a header file, I didn't have to create a library with source files. The header file basically contained definitions that I didn't want to rewrite in the c code every time.
So, in the Arduino environment, can I include a header file that is not part of a library?
If the include file is part of a single Sketch, instructions are here...
http://www.arduino.cc/en/Hacking/BuildProcess
If the include file is meant to be shared by multiple Sketches then...
  • Close the Arduino IDE
  • Navigate to the {Arduino}\hardware\libraries directory
  • Create a subdirectory. I suggest something like MyCommon.
  • In the new subdirectory, create a header file. I suggest something like MyCommon.h.
  • Open the new header file, edit it as you wish, and save it
  • Open the Arduino IDE
  • Create or open a Sketch
  • Add a #include to the top of the Sketch that references your new include file
Perfect! Thanks for the reply. That is exactly what I was looking for.
