Can I program sensors into "distance" IF comments?
Aloha! I'm trying to figure out how to program my "IF" comments to coincide with distance on two of my ultrasonic sensors. I want them to turn on separate LED's individually according to what is in their path. For example:
Is it okay if I code:
  if (leftSensorEchoPin distance < minRange){
 /* Send the distance to the computer using Serial protocol, and
 turn LED OFF to indicate successful reading. */
 Serial.println(distance);
 digitalWrite(leftLEDMosfet, LOW);
and
 if (rightSensorEchoPindistance < minRange){
 digitalWrite(rightLEDMosfet, LOW);
Or, if incorrect, how would I do that for each individual sensor? Thank you!
The code looks OK apart from the missing closing braces on the code blocks, but I assume that these are in your complete program. A small improvement would be to make the second if into an else/if unless it is possible that both sensors could return a distance less than minRange.
Hey guys. I keep getting the following error message when attempting this with a practice code
sketch_sep21a:41: error: expected ')' before 'distance'
   if (righttrigPin distance < 4) {  // This is where the LED On/Off happens
exit status 1
Here's my code:
#define righttrigPin 9
#define rightechoPin 8
#define lefttrigPin 13
#define leftechoPin 12
#define led 11
#define led2 10
#define led3 7
#define led4 6
  Serial.begin (9600);
  pinMode(righttrigPin, OUTPUT);
  pinMode(rightechoPin, INPUT);
  pinMode(lefttrigPin, OUTPUT);
  pinMode(leftechoPin, INPUT);
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  long duration, distance;
  digitalWrite(lefttrigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(lefttrigPin, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(leftechoPin, HIGH);
  distance = (duration/2) / 29.1;
  digitalWrite(righttrigPin, LOW);  // Added this line
  digitalWrite(righttrigPin, HIGH);
  duration = pulseIn(rightechoPin, HIGH);
  if (righttrigPindistance < 4) {  // This is where the LED On/Off happens
    digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
  digitalWrite(led2,LOW);
  else {
    digitalWrite(led,LOW);
    digitalWrite(led2,HIGH);
    digitalWrite(led3, LOW);
    digitalWrite(led4, HIGH);
  if (distance >= 200 || distance <= 0){
    Serial.println("Out of range");
  else {   0
    ;Serial.print(distance);
    Serial.println(" cm");
Not sure why this error message was emitted, but variable names cannot contain blanks.
You have not defined a variable named "righttrigPindistance"
jremington:
Ah, gotcha. So if I were wanting to define this variable, or multiple distance variables, where would I add them? Thanks!
