Can I Read/Write a standard SDcard(in a card reader)via the DUE Native USB port?
If so, how?
I wouldn't need to add a shield then....
  • Thanks
Not really, no - SD cards don't use USB for communication. <--- this is the important bit.
They use either SPI (a 3 +n wire data bus [where n = the number of SPI nodes on the bus]) or the full number of data pins on the card.
The SAM3X8E chip has a dedicated memory interface to deal with SD cards, that uses the data pins on a card. Or of course you can just use SPI - there are libraries for this, although I'm not sure they're supported by the Due yet.
Actually, this was poorly phrased.
I can buy a whole host of SD card reader/writers to connect an SD card via USB my Mac for cheap.
http://www.frys.com/search?search_type=regular&sqxts=1&query_string=sd+card+usb&submit.x=-410&submit.y=-151&cat=0
So some sort of USB/SDcard interface is going on there.
And I see that the Due has a USB interface as well.
can I make the DUE<->USB<->USB/SDcardReader<->SDcard path work via software, or do I need an SDcard shield?
Hello paseman,
You can read/write from/to a SDcard via the Due Native USB port. I've done that using the Atmel AS6 ASF example called "USB Host MSC FatFS", with a card reader and a 1.0GB SDcard (FAT).
http://www.frys.com/product/5815313
It also worked with a Flash pen drive:
I believe that it doesn't matter the SDcard or Flash card you use. I have tested the code only with one memory device at a time. The only problem with this application is that, AFAIK, there is no ported code from Atmel Studio to Arduino. It is not hard to do it.
I started a thread some time ago:
http://forum.arduino.cc/index.php?topic=135218.msg1016939#msg1016939
I hope this help. Regards!
helps a lot!
Thanks.
Ah, I see what you mean now - yes, as Palliser has said, this is possible.
