Can not properly set pin13 to low
I did the following:
#include <WProgram.h>
#include <string.h>
#include <pins_arduino.h>
// will initialize output pin with 1, then measure time for  input pin go to high
typedef int32_t micros_type;
// output pin
const uint8_t c_output_pin = 13; // internal LED is connected to digital pin 13
const uint8_t c_output_pin__bit  = 5;                                    // lookup in pins_arduino.c
// attention: input pin and break pin must use the same port !!!
const uint8_t c_input_pin  = 19;  // used as primary trigger pin
const uint8_t c_input_pin__bit  = 5;
int32_t measure_lag_micros;
int32_t measure_lag() {
     pinMode(c_input_pin, INPUT);
       digitalWrite(c_input_pin, HIGH);
      // output to low because we want to trigger with high
      // because the opto coupler will turn this to low again
      pinMode(c_output_pin, OUTPUT);
        digitalWrite(c_output_pin, HIGH);
      // compute pin ports and bit masks in advance
        volatile uint8_t* in_port   = portInputRegister(digitalPinToPort(c_input_pin));
        volatile uint8_t* out_port  = portInputRegister(digitalPinToPort(c_output_pin));
        //volatile uint8_t* break_port = portInputRegister(digitalPinToPort(c_break_pin));
            uint8_t in_bit     = 1 << c_input_pin__bit;
            uint8_t out_bit    = 1 << c_output_pin__bit;
        // ensure that we will never see 0 microseconds in the assembler part
        // this is because it would wrap around and give way to long delays
        // impact is that latency will never be below 1 microsecodns
        const micros_type timeout = 99999999;
        measure_lag_micros = timeout;
    uint8_t tmp = 0;
      cli();
        // the inline assembler loop will burn 16 cycles or 1 microsecond at 16 MHz
      // for details:
      //            http://www.rn-wissen.de/index.php/Inline-Assembler_in_avr-gcc
      //            http://www.avr-asm-tutorial.net/avr_de/beginner/register.html
      //            http://www.avr-asm-tutorial.net/avr_en/beginner/PDETAIL.html#IOPORTS
      __asm__ __volatile__ (
            //       activate output
            "   eor  %[tmp], %[tmp]"   "\n\t"  // set output to low
            "   st  %a[out_port], %[tmp]" "\n\t"   // now
        // the loop below will take exactly 16 cycles per pass = 1us at 16 MHz
            "1: nop"                       "\n\t"
            "   nop"                      "\n\t"
            "   nop"                      "\n\t"
            "   nop"                      "\n\t"
            "   nop"                      "\n\t"
            "   ld  %[tmp], %a[in_port]"  "\n\t" // 2 cycles
            "   and %[tmp], %[in_bit]"    "\n\t" // 1 cycle
            "   cp  %[tmp], %[in_bit]"    "\n\t" // 1 cycle
            "   breq 2f"                       "\n\t" // 1 cycle    // stop timing once we see a high
            "   subi %A[micros],1"             "\n\t" // subtract immediate,  1 cycle
            "   sbci %B[micros],0"             "\n\t" // subtract with carry, 1 cycle
            "   sbci %C[micros],0"             "\n\t" // subtract with carry, 1 cycle
            "   sbci %D[micros],0"             "\n\t" // subtract with carry, 1 cycle
            "   brne 1b"                       "\n\t" //                      2 cycles (1 in the last pass)
            "2: nop"  "\n\t"
            : [micros]     "+a" (measure_lag_micros)   // constraint: simple upper register
            :              "0"  (measure_lag_micros),  // constraint: use same register as [micros]
              [in_port]    "e" (in_port),              // constraint: pointer register
              [in_bit]     "a" (in_bit),               // constraint: simple upper register
              [out_port]   "e" (out_port),             // constraint: pointer register
              [out_bit]    "a" (out_bit),              // constraint: simple upper register
              [tmp]        "a" (tmp)                     // constraint: simple upper register
        measure_lag_micros = timeout - measure_lag_micros;
        sei();
        return measure_lag_micros;
int main(){
      Serial.println("ready");
      for (;;) {
            micros_type rv;
            rv = measure_lag();
            if (rv>0) {
            Serial.println(rv ,DEC); }
(Sorry for the messed up tabs).
The issue is: if I code a digitalWrite(13,LOW) it will set pin 13 to low. But if I do not it will not.
However I would expect that
would set pin 13 to low. But it fails to do so. Can anyone hit me with a cluebat?
Cheers, Udo
Why are you not using the standard Arduino setup() and loop() functions rather then using a main() function?
Lefty
This code is part of a bigger project. I extracted it. The reason why I do not use the IDE is because I do not like it. It always gives me some kind of trouble. For example I can not define prototypes, compiler errors do not refer to proper line numbers and more. The libraries and the bootloader are a big help, but the IDE not really.
But this is definitely not the issue here. If I move this into a "normal" sketch the issue persists.
Aargh!
I thought the bug is in the assembly code, but
should have been
  volatile uint8_t* out_port  = portOutputRegister(digitalPinToPort(c_output_pin));
Sorry for the stupid question.
Cheers, Udo
(lowers his cluebat...)
b
