I am making a simulator box that pretends to be an industrial pump. We make equipment that interfaces with the pump and don't always have a pump available to test the connection. I used and arduino uno with an ethernet shield 2 to do this. The manufacturer of the pump has a very simple communication scheme. A 10 byte packet is sent to the pump via UDP once a second. The IP address and port on the pump are fixed.
I wrote a simple sketch that looks for the 10 byte UDP packet and then does some bitwise examination, then illuminates some LEDs.
Everything seemed to work great at first. I did my initial testing, I would get the packet, the bits would match, LEDs would illuminate. When I went back and tested it again it would not receive anything. parsePacket() always returns zero. The ethernet link is established, the amber LED on the ethernet shield flashes once a second but nothing shows up.
I have two machines that are in known good working order and neither would work with the arduino. They both worked during the initial testing. We do currently have a pump and both machines will operate the pump with no problems.
On a whim I rebooted one of the machines and packets started to show up again on the arduino when connected to that machine. The other machine still shows nothing on the arduino and both machines will operate the pump.
I tried connecting to them with wire shark. I can see both machines sending a 10 byte UDP packet. The source and destination IPs are correct, the port is correct as well. I bet that if I reboot the other machine that it will start working with arduino again.
I'm using the 2.0.2 Ethernet library.
I'm at a loss as to what to trouble shoot next?
#include <Ethernet.h>
#include <EthernetUdp.h>
#define PUMP_ON 9
#define LOW_PRESSURE 8
#define CUTTING_HEAD_OPEN 7
#define LINK_ESTABLISHED 6
#define HEAERT_BEAT 5
// MAC address and IP.
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAF, 0x01, 0x92 };
IPAddress ip(172, 16, 0, 106);
// The local port to listen for connections on.
unsigned int localPort = 8682;
// The maximum number of characters to receive from an incoming packet
#define MAX_PACKET_LENGTH 100
// Buffer for holding received packets.
char packetReceived[MAX_PACKET_LENGTH];
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
union uint_double_char {
unsigned int Integer;
unsigned char Character[2];
union BFT_COMMAND_DATA {
struct {
bool start : 1;
bool stop : 1;
bool reset : 1;
bool pressure_relief : 1;
bool adjusting_jet : 1;
bool enable : 1;
bool high_low : 1;
bool valve : 1;
unsigned char data;
enum ESTOP_CHECK_STATE_MACHINE {
ALL_OFF = 0,
PAIR_1_ASSERT,
PHASE_1_CHECK_1,
PHASE_1_CHECK_2,
PAIR_2_ASSERT,
PHASE_2_CHECK_2,
PHASE_2_CHECK_1
enum ESTOP_CHECK_STATE_MACHINE estop_state_machine = ALL_OFF;
enum ESTOP_CHECK_STATE {
OFF = 0,
OK,
CROSS_WIRED_OR_SHORTED
enum ESTOP_CHECK_STATE estop_circuit_1 = OFF, estop_circuit_2 = OFF;
union BFT_COMMAND_DATA bft_command_data;
union uint_double_char conversion;
pinMode(HEAERT_BEAT, OUTPUT);
pinMode(LINK_ESTABLISHED, OUTPUT);
digitalWrite(LINK_ESTABLISHED, HIGH);
pinMode(PUMP_ON, OUTPUT);
digitalWrite(PUMP_ON, HIGH);
pinMode(LOW_PRESSURE, OUTPUT);
digitalWrite(LOW_PRESSURE, HIGH);
pinMode(CUTTING_HEAD_OPEN, OUTPUT);
digitalWrite(CUTTING_HEAD_OPEN, HIGH);
// pinMode(ESTOP_CIRCUIT_ICICATOR_1, OUTPUT);
// digitalWrite(ESTOP_CIRCUIT_ICICATOR_1, HIGH);
// pinMode(ESTOP_CIRCUIT_ICICATOR_2, OUTPUT);
// digitalWrite(ESTOP_CIRCUIT_ICICATOR_2, HIGH);
// pinMode(ESTOP_CIRCUIT_EXCITE_1, OUTPUT);
// pinMode(ESTOP_CIRCUIT_EXCITE_2, OUTPUT);
Ethernet.begin(mac, ip);
static unsigned long time_second = 0;
if (millis() - time_second > 1000) {
time_second = millis();
static bool light = false;
light ^= 1;
digitalWrite(HEAERT_BEAT, light);
static bool Link_Established = false;
if ((Ethernet.linkStatus() == LinkON) && (Link_Established == false)) {
// Begin listening on the local port for UDP datagrams
Udp.begin(localPort);
Link_Established = true;
Serial.println("link established");
if ((Ethernet.linkStatus() == LinkOFF) && (Link_Established == true)) {
//Udp.stop();
if (Link_Established == true) {
digitalWrite(LINK_ESTABLISHED, LOW);
// Look for a received packet.
int packetSize = Udp.parsePacket();
//Serial.println(packetSize);
if (packetSize > 0) {
Serial.print("Received packet of size ");
Serial.print(packetSize);
Serial.println(" bytes.");
Serial.print("Remote IP: ");
IPAddress remote = Udp.remoteIP();
for (int i = 0; i < 4; i++) {
if (i < 3) {
Serial.print(remote[i], DEC);
Serial.print(".");
Serial.println(remote[i], DEC);
Serial.print("Remote port: ");
Serial.println(Udp.remotePort());
// Read the packet.
int bytesRead = Udp.read(packetReceived, MAX_PACKET_LENGTH);
Serial.print("Packet contents: ");
Serial.write(packetReceived, bytesRead);
conversion.Character[0] = packetReceived[4];
conversion.Character[1] = packetReceived[5];
Serial.println(conversion.Integer, BIN);
bft_command_data.data = packetReceived[4];
Serial.print(bft_command_data.valve);
Serial.print(" ");
Serial.print(bft_command_data.high_low);
Serial.print(" ");
Serial.print(bft_command_data.enable);
Serial.print(" ");
Serial.print(bft_command_data.adjusting_jet);
Serial.print(" ");
Serial.print(bft_command_data.pressure_relief);
Serial.print(" ");
Serial.print(bft_command_data.reset);
Serial.print(" ");
Serial.print(bft_command_data.stop);
Serial.print(" ");
Serial.println(bft_command_data.start);
if (bft_command_data.start == 1) {
digitalWrite(PUMP_ON, LOW);
if (bft_command_data.high_low == 1) {
digitalWrite(LOW_PRESSURE, LOW);
if (bft_command_data.valve == 1) {
digitalWrite(CUTTING_HEAD_OPEN, LOW);
