I have built this Hollow Clock and the code they are using relies on the time to be kept by using the mills math. I want to keep the code the sameish, but use an RTC and every time the minute advances, advance the rotate loop to advance the hand 1 minute. I'm not good enough to rewrite someone else's code.
Any help, Thanks
// Please tune the following value if the clock gains or loses.
// Theoretically, standard of this value is 60000.
#define MILLIS_PER_MIN 59100 // milliseconds per a minute
// Motor and clock parameters
// 4096 * 90 / 12 = 30720
#define STEPS_PER_ROTATION 30720 // steps for a full turn of minute rotor
// wait for a single step of stepper
int delaytime = 2;
// ports used to control the stepper motor
// if your motor rotate to the opposite direction,
// change the order as {2, 3, 4, 5};
int port[4] = {2, 3, 4, 5};
// sequence of stepper motor control
int seq[8][4] = {
{ LOW, HIGH, HIGH, LOW},
{ LOW, LOW, HIGH, LOW},
{ LOW, LOW, HIGH, HIGH},
{ LOW, LOW, LOW, HIGH},
{ HIGH, LOW, LOW, HIGH},
{ HIGH, LOW, LOW, LOW},
{ HIGH, HIGH, LOW, LOW},
{ LOW, HIGH, LOW, LOW}
void rotate(int step) {
static int phase = 0;
int i, j;
int delta = (step > 0) ? 1 : 7;
int dt = 20;
step = (step > 0) ? step : -step;
for(j = 0; j < step; j++) {
phase = (phase + delta) % 8;
for(i = 0; i < 4; i++) {
digitalWrite(port[i], seq[phase][i]);
delay(dt);
if(dt > delaytime) dt--;
// power cut
digitalWrite(port[i], LOW);
pinMode(port[0], OUTPUT);
pinMode(port[1], OUTPUT);
pinMode(port[2], OUTPUT);
pinMode(port[3], OUTPUT);
rotate(-20); // for approach run
rotate(20); // approach run without heavy load
rotate(STEPS_PER_ROTATION / 60);
static long prev_min = 0, prev_pos = 0;
long min;
static long pos;
min = millis() / MILLIS_PER_MIN;
if(prev_min == min) {
return;
prev_min = min;
pos = (STEPS_PER_ROTATION * min) / 60;
if(pos - prev_pos > 0) {
rotate(pos - prev_pos);
prev_pos = pos;
