Can someone help explain what Hex String & Hex in this code does?
#include <LEDStripDriver.h>
// use two available GPIO pins from your board
// DIN=GPIO16, CIN=GPIO14 in this example
LEDStripDriver led = LEDStripDriver(16, 14);
  led.setColor(255, 0, 0); // RGB
  led.setColor("#00FF00"); // Hex String
  led.setColor(0x0000FF); // Hex
  led.setColor(); // turn off
Here is the source of the code if its any help: GitHub - MrKrabat/LED-Strip-Driver-Module: Arduino library for the full color RGB LED strip driver module shield
It looks like the setColor() function takes 3 values, one each for red, green and blue at a guess
So to set the colour of an LED you need to send either 6 characters such as "00FF00" to set red to zero, green to FF and blue to zero. The # is presumably used by the library for some purpose. An alternative format would seem to be the normal hex notation of 0x00FF00 (not a string) that sets the colours to the same values
This is based on guesswork as I do not have the LEDStripDriver library
The code just shows the 3 different options available for passing data to setcolor(). "#00FF00" is equivalent to 0, 255, 0 (green) and 0x0000FF = 0, 0, 255 (blue).
Steve
This is a standard represenation for RGB colour used in many different pieces of software, notable HTML/CSS.
I have attached the library below.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "broker.mqttdashboard.com";
const char* mqtt_user = "";
const char* mqtt_pswd = "";
char messageBuffer[50];
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long currentTime;
unsigned long startTime;
unsigned long period = 1000;
bool power = false;
void setup_wifi()
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.print("connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  delay(2000);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  client.loop();
  if (!client.connected())
    reconnect();
  if (power == true)
    RainbowEffect();
void reconnect()
  while (!client.connected())
    Serial.println("Attempting MQTT connection...");
    if (client.connect("Reception"))
      Serial.println("Connected to MQTT server");
      client.subscribe("RGB/Output");
      Serial.print("Failed to connect to MQTT...");
      Serial.println("Attempting to connect again in 3 seconds.");
      delay(3000);
void callback(char* topic, byte* payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  Serial.print("length : ");
  Serial.println(length);
  memcpy(messageBuffer, payload, length);
  messageBuffer[length] = '\0';
  Serial.print("the payload is : ");
  Serial.println(messageBuffer);
  if (strcmp(messageBuffer, "on") == 0)
      Serial.print("turning ");
      digitalWrite(LED_BUILTIN, LOW);
      power = true; //activate rainbow
  else if (strcmp(messageBuffer, "off") == 0)
      digitalWrite(LED_BUILTIN, HIGH);
      OffRainbow();
      power = false;  //stop the rainbow
void OffRainbow()
void RainbowEffect()
  currentTime = millis();
  if (currentTime - startTime >= period)
    for (uint16_t color = 0; color < 256; color++) {
    led.setColor(color, color, color);}
    startTime = currentTime;
I'm trying to integrate it to this code. Everything except RainbowEffect works(Led does not light up when given command). How shld I cycle thorugh colours of the led strip, in this case?
LED-Strip-Driver-Module-master.zip (106 KB)
Check your brace pairing vs indentation....
That code always sets startTime equal to currentTime. Therefore the if statement never executes.
Edit: Also it’s not going to be a very effective effect if you do ALL of the steps of the rainbow in one go, and then wait for “period” milliseconds without doing anything. But that’s a different problem....
Edit again: Or indeed give a “rainbow” effect if the 3 values represent RGB intensities.
pcbbc:
    for (uint16_t r = 0; r < 256; r++)
      for (uint16_t b = 0; b < 256; b++)
        for (uint16_t g = 0; g < 256; g++)
          led.setColor(r, b, g);
I just tested the code, the led remained white and is unable to turn off when given command. How else do I give it a rainbow effect without using the nested for loop?
    countR++;
    if (countR > 1)
      countR = 0;
      countG++;
      if (countG > 1)
        countG = 0;
        countB++;
        if (countB > 1)
          countB = 0;
    led.setColor(countR,countG,countB);
I tried if else statement & strip remains off. Is there something wrong with the code above?
