Hello everyone.
I am working on one project. I don't have any experience with Arduino and coding.
I am getting errors when I am trying to upload code to my Arduino Nano every.
ERRORS;
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano Every, ATMEGA328"
WARNING: library U8glib claims to run on avr, sam architecture(s) and may be incompatible with your current board which runs on megaavr architecture(s).
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c: In function 'u8g_spi_out':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:184:3: error: 'SPDR' undeclared (first use in this function); did you mean 'SDA'?
SPDR = data;
SDA
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:184:3: note: each undeclared identifier is reported only once for each function it appears in
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:186:12: error: 'SPSR' undeclared (first use in this function); did you mean 'SPDR'?
while (!(SPSR & (1<<SPIF)))
SPDR
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:186:23: error: 'SPIF' undeclared (first use in this function); did you mean 'SPI0'?
SPI0
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c: In function 'u8g_com_arduino_hw_spi_fn':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:220:7: error: 'SPCR' undeclared (first use in this function); did you mean 'SCL'?
SPCR = 0;
SCL
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:19: error: 'SPE' undeclared (first use in this function); did you mean 'PE'?
SPCR = (1<<SPE) | (1<<MSTR)|(0<<SPR1)|(0<<SPR0)|(0<<CPOL)|(0<<CPHA);
PE
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:30: error: 'MSTR' undeclared (first use in this function); did you mean 'PSTR'?
PSTR
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:40: error: 'SPR1' undeclared (first use in this function); did you mean 'SPE'?
SPE
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:50: error: 'SPR0' undeclared (first use in this function); did you mean 'SPR1'?
SPR1
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:60: error: 'CPOL' undeclared (first use in this function); did you mean 'CCL'?
CCL
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:221:70: error: 'CPHA' undeclared (first use in this function); did you mean 'CPOL'?
CPOL
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:227:2: error: 'SPSR' undeclared (first use in this function); did you mean 'SPCR'?
SPSR = (1 << SPI2X); /* double speed, issue 89 */
SPCR
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_hw_spi.c:227:15: error: 'SPI2X' undeclared (first use in this function); did you mean 'SPI_t'?
SPI_t
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c: In function 'u8g_com_arduino_port_d_8bit_wr':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c:72:9: error: incompatible types when assigning to type 'PORT_t {aka struct PORT_struct}' from type 'uint8_t {aka unsigned char}'
PORTD = val;
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c: In function 'u8g_com_arduino_port_d_wr_fn':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c:91:7: error: 'DDRD' undeclared (first use in this function); did you mean 'DD7'?
DDRD = 0x0ff;
DD7
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c:91:7: note: each undeclared identifier is reported only once for each function it appears in
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_port_d_wr.c:92:13: error: incompatible types when assigning to type 'PORT_t {aka struct PORT_struct}' from type 'int'
PORTD = 0x0ff;
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c: In function 'u8g_arduino_st7920_hw_spi_shift_out':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:102:3: error: 'SPDR' undeclared (first use in this function); did you mean 'SDA'?
SPDR = val;
SDA
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:102:3: note: each undeclared identifier is reported only once for each function it appears in
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:104:12: error: 'SPSR' undeclared (first use in this function); did you mean 'SPDR'?
SPDR
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:104:23: error: 'SPIF' undeclared (first use in this function); did you mean 'SPI0'?
SPI0
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c: In function 'u8g_com_arduino_st7920_hw_spi_fn':
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:204:7: error: 'SPCR' undeclared (first use in this function); did you mean 'SCL'?
SPCR = 0;
SCL
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:19: error: 'SPE' undeclared (first use in this function); did you mean 'PE'?
SPCR = (1<<SPE) | (1<<MSTR)|(0<<SPR1)|(0<<SPR0)|(1<<CPOL)|(1<<CPHA);
PE
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:30: error: 'MSTR' undeclared (first use in this function); did you mean 'PSTR'?
PSTR
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:40: error: 'SPR1' undeclared (first use in this function); did you mean 'SPE'?
SPE
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:50: error: 'SPR0' undeclared (first use in this function); did you mean 'SPR1'?
SPR1
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:60: error: 'CPOL' undeclared (first use in this function); did you mean 'CCL'?
CCL
C:\Users\senca\Documents\Arduino\libraries\U8glib\src\clib\u8g_com_arduino_st7920_hw_spi.c:207:70: error: 'CPHA' undeclared (first use in this function); did you mean 'CPOL'?
CPOL
exit status 1
Error compiling for board Arduino Nano Every.
option enabled in File -> Preferences.
