I'm making a keypad unlock door lock. Im new to Arduino and so I don't know most of the codes.
Can someone please correct my code?
#include <Servo.h>
#include <Keypad.h>
Servo ServoMotor;
char* "999";
int position = 0;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'','0','#','D'}
byte rowPins[ROWS] = { 8, 7, 6, 9 };
byte colPins[COLS] = { 5, 4, 3, 2 };
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int RedpinLock = 12;
int GreenpinUnlock = 13;
ServoMotor.attach(11);
LockedPosition(true);
char key = keypad.getKey();
if (key == ' ' || key == '#')
position = 0;
if (key == password[position])
position ++;
if (position == 3)
LockedPosition(false);
delay(100);
void LockedPosition(int locked)
if (locked)
digitalWrite(RedpinLock, HIGH);
digitalWrite(GreenpinUnlock, LOW);
ServoMotor.write(11);
digitalWrite(RedpinLock, LOW);
digitalWrite(GreenpinUnlock, HIGH);
ServoMotor.write(90);
LarryD
April 18, 2021, 6:23pm
2
First off we need the sketch posted properly.
In the Arduino IDE, use CTRL T to format your code then copy the complete sketch .
Use the </> button from the ‘reply menu’ to attach the copied sketch.
#include <Servo.h>
#include <Keypad.h>
Servo ServoMotor;
char* "999";
int position = 0;
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
if (key == '*' || key == '#')
position = 0;
position ++;
if (position == 3)
delay(100);
if (locked)
Welcome to the forum.
You will be better of if we teach you how to fish and not when we catch the fish for you.
I would recommend you have a look at a few examples in the IDE first and use Google to search for terms you do not understand.
File -> Examples -> ...
If something is unclear, post some specific questions and you will get lots of answers.
Have a look at the brackets in your code. Every opening bracket needs a closing bracket of the same type. Formatting your code already shows you something is wrong.
How are your components wired together ?
A simple schematic (not a Frizzy diagram) please.
A (clear, well lit) photo of your project may help too.
Do you want to give us a few more hints? What Arduino? Does your code compile? And upload? When you run it what EXACTLY does it do?
Steve
char * "999";
is not a valid statement. If you are creating a variable, you have to give it a name.
There is an extra set of curly braces around this block of statements. Get rid of them, and the ';' at the end.
The variable 'password' is not declared. I'm guessing you meant 'char * "999";' to be 'const char * password = "999";' or you could use 'char password[] = "999";' if you ever want to change those three characters in your sketch.
There is an extra '}' after the LockedPosition() function.
system
Closed
August 16, 2021, 8:27pm
8
