I found this great Earle Philhower FIFI two core example that runs fine with his Pico RP2040 Board with Arduino IDE on my Win11 (fifoTest below) , but reversing everything didn’t work (fifoTest1 below). When it doesn’t crash the bootloader and require board replacement, it compiles, loads and hangs with, “Port monitor error: Command ‘open’ failed. Serial port busy. Could not connect to COM8.”
I’ve tried everything I can think of to no avail. What am I missing?
fifoTest.ino
// This FIFI ADC Core1 to Core0 works great
// All compliments to https://github.com/earlephilhower/arduino-pico/discussions/83
// Tweeking by Larry Gorham
// Core 1 interrupt Handler
void core1_interrupt_handler() {
// Receive Raw Value
while (multicore_fifo_rvalid()){
uint32_t raw = multicore_fifo_pop_blocking();
Serial.printf("ADC = %d\n", raw);
multicore_fifo_clear_irq(); // Clear interrupt
// Core 1 Main Code
void core1_entry() {
// Configure Core 1 Interrupt
delay(3000);
irq_set_exclusive_handler(SIO_IRQ_PROC1, core1_interrupt_handler);
irq_set_enabled(SIO_IRQ_PROC1, true);
// Infinite While Loop to wait for interrupt
while (1){
//tight_loop_contents(); //noop instruction requires no time
// Core 0
delay(4000);
multicore_launch_core1(core1_entry); // Start core 1 - Do this before any interrupt configuration
uint32_t raw = analogRead(A0);
multicore_fifo_push_blocking(raw);
sleep_ms(1000);
fifoTest1.ino
// Just trying to FIFO ADC Core1 to Core0
// This code hangs port and/or eats bootloader
void core0_interrupt_handler() {
// Receive Raw Value,
// Core 0 Main Code
delay(3000);
irq_set_exclusive_handler(SIO_IRQ_PROC0, core0_interrupt_handler);
irq_set_enabled(SIO_IRQ_PROC0, true);
while (1){
// Core 1
void setup1() {
delay(4000);
//multicore_launch_core0(core0_entry); //Core0 normally first
void loop1() {
sleep_ms(1000);
