I want to use 5V triggers to control 12V or 24V DC circuits in PWM speed control.
Can this board be used for this, with just opto-couplers without a MOSFET?
Please give a link to the data sheet of a specific module.
Motors or other load?
Motor current? Max. 10mA without a MOSFET.
One direction only?
Precise speed control required?
Not sure if I was doing the same thing here. But this was a thread where I used an opticoupler to drive a 12V PWM fan. There was no Mosfet involved and it worked really well.
I'd guess the BMW fan has a MOSFET controller built-in. 600W / 12V = 50 Amps!!!
It is a Mercedes fan, 600W, may very well be the same Bosch motor as in the BMW. I have no idea whats inside the motor. All I had to do was ground the signal at 10Hz at a controlled duty cycle with the opticoupler.
Link corrected: https://www.aliexpress.com/item/4000459030365.html
It cannot directly drive any sort of motor, light or other device at all.
Which only works if there's a driver built into the fan. In general when someone says "I need to pwm somrthing on 12V" best assume a driver is NOT yet part of the system. The fact that you happened to have the driver built into your device is the exception, not the tule.
