and ps3_usb.cpp file is:
/* ps3_usb.cpp - PS3 Game Controller on Arduino USB Host Library
Copyright (c) 2009 Richard Ibbotson richard.ibbotson@btinternet.com
All right reserved. This library is free software; you can redistribute it
and/or modify it under the terms of the GNU Lesser General Public License
as published by the Free Software Foundation; either version 2.1 of the License,
or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
or FITNESS FOR A PARTICULAR PURPOSE.
See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public License along
with this library; if not, write to the Free Software Foundation, Inc.,
51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
#include "ps3_usb.h"
static unsigned char ps3_status;
static unsigned int oldbuttonstate;
static unsigned char oldpsbuttonstate;
prog_char output_01_report[] PROGMEM = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x02, 0xff, 0x27, 0x10, 0x00, 0x32, 0xff,
0x27, 0x10, 0x00, 0x32, 0xff, 0x27, 0x10, 0x00,
0x32, 0xff, 0x27, 0x10, 0x00, 0x32, 0x00, 0x00,
prog_char feature_F4_report[] PROGMEM = {0x42, 0x0c, 0x00, 0x00};
EP_RECORD ep_record[ PS3_NUM_EP ]; //endpoint record structure for the PS3 controller
TYPE_01_REPORT report;
MAX3421E Max;
USB Usb;
/* constructor */
PS3_USB::PS3_USB() {
void PS3_USB::init(void){
Max.powerOn();
delay(200);
void PS3_USB::task(void){
Max.Task();
Usb.Task();
if( Usb.getUsbTaskState() == USB_DETACHED_SUBSTATE_INITIALIZE) { //reinitialised
ps3_status = 0;
if( Usb.getUsbTaskState() == USB_STATE_CONFIGURING ) { //wait for addressing state
PS3_init();
if( ps3_status & statusPS3Connected) Usb.setUsbTaskState( USB_STATE_RUNNING );
if( Usb.getUsbTaskState() == USB_STATE_RUNNING ) { //poll the PS3 Controller
PS3_poll();
/* Initialize PS3 Controller /
void PS3_USB::PS3_init( void )
byte rcode = 0; //return code
char buf[ 64 ] = { 0 }; //General purpose buffer for usb data
byte i;
USB_DEVICE_DESCRIPTOR device_descriptor;
ps3_status = statusDeviceConnected;;
/* Initialize data structures for endpoints of device */
ep_record[ CONTROL_PIPE ] = *( Usb.getDevTableEntry( 0,0 )); //copy endpoint 0 parameters
ep_record[ OUTPUT_PIPE ].epAddr = 0x02; // PS3 output endpoint
ep_record[ OUTPUT_PIPE ].Attr = EP_INTERRUPT;
ep_record[ OUTPUT_PIPE ].MaxPktSize = EP_MAXPKTSIZE;
ep_record[ OUTPUT_PIPE ].Interval = EP_POLL;
ep_record[ OUTPUT_PIPE ].sndToggle = bmSNDTOG0;
ep_record[ OUTPUT_PIPE ].rcvToggle = bmRCVTOG0;
ep_record[ INPUT_PIPE ].epAddr = 0x01; // PS3 report endpoint
ep_record[ INPUT_PIPE ].Attr = EP_INTERRUPT;
ep_record[ INPUT_PIPE ].MaxPktSize = EP_MAXPKTSIZE;
ep_record[ INPUT_PIPE ].Interval = EP_POLL;
ep_record[ INPUT_PIPE ].sndToggle = bmSNDTOG0;
ep_record[ INPUT_PIPE ].rcvToggle = bmRCVTOG0;
Usb.setDevTableEntry( PS3_ADDR, ep_record ); //plug kbd.endpoint parameters to devtable
delay(200); // give time for address change
/* read the device descriptor and check VID and PID*/
rcode = Usb.getDevDescr( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, DEV_DESCR_LEN , buf );
if( rcode ) return;
device_descriptor = (USB_DEVICE_DESCRIPTOR *) &buf;
if(
(device_descriptor->idVendor != PS3_VID) ||(device_descriptor->idProduct != PS3_PID) ) return;
/* Configure device */
rcode = Usb.setConf( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_CONFIGURATION );
if( rcode ) return;
ps3_status |= statusUSBConfigured;
/* Set the PS3 controller to send reports */
for (i=0; i < PS3_F4_REPORT_LEN; i++) buf = pgm_read_byte_near( feature_F4_report + i);
- rcode = Usb.setReport( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_F4_REPORT_LEN, PS3_IF, HID_REPORT_FEATURE, PS3_F4_REPORT_ID , buf );*
- if( rcode ) return;*
_ /* Set the PS3 controller LED 1 On /_
for (i=0; i < PS3_01_REPORT_LEN; i++) buf = pgm_read_byte_near( output_01_report + i);
rcode = Usb.setReport( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_01_REPORT_LEN, PS3_IF, HID_REPORT_OUTPUT, PS3_01_REPORT_ID , buf );
_ if( rcode ) return;*_
* ps3_status |= statusPS3Connected;*
/* Poll PS3 interrupt pipe and process result if any */
void PS3_USB::PS3_poll( void )
_ /* poll PS3 /_
rcode = Usb.inTransfer(PS3_ADDR, ep_record[ INPUT_PIPE ].epAddr, PS3_01_REPORT_LEN, (char ) &report );
_ if( rcode ) return;_
* ps3_status |= statusReportReceived;
_ return;_
_}_
unsigned char PS3_USB::getStatus( void ){
return( ps3_status);
_}_
bool PS3_USB::statConnected( void){
return(ps3_status & statusPS3Connected);
_}_
bool PS3_USB::statReportReceived( void){
bool rvalue = ps3_status & statusReportReceived;
ps3_status &= ~statusReportReceived; // clear the report received flag*
* return(rvalue);*
unsigned char PS3_USB::getJoystick(unsigned char joy){
* if (joy > 3) return(128); // not valid joystick*
_ return( (&report.LeftStickX + joy));_
_}_
unsigned int PS3_USB::getMotion(unsigned char accel ){
_ if(accel > 3) return(512);_
_ return( byteswap((&report.AccelX + accel)));
unsigned char PS3_USB::getPressure(unsigned char button ){
* if ((button < 4) || (button > 15)) return(0);*
return((&report.PressureUp + button - 4));_
_}_
bool PS3_USB::buttonChanged(void){
_ if ((report.ButtonState != oldbuttonstate) || (report.PSButtonState != oldpsbuttonstate)){_
_ oldbuttonstate = report.ButtonState;_
_ oldpsbuttonstate = report.PSButtonState;_
_ return(true);_
_ }_
_ return(false);_
_}_
bool PS3_USB::buttonPressed(unsigned char button){
_ if(button == 16) return( report.PSButtonState & 0x01);_
_ return(report.ButtonState & (1 << button));*_
void PS3_USB::LEDRumble(unsigned char ledrum){
unsigned char i;
/* default buffer values */
_ /* LED setings /
buf[9] = (ledrum & 0x0f) << 1;
/ rumble settings /
if (ledrum & 0x30){
buf[1] = buf[3] = 0xfe;
if (ledrum & 0x10) buf[4] = 0xff;
else buf[2] = 0xff;
}*_
* Usb.setReport( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_01_REPORT_LEN, PS3_IF, HID_REPORT_OUTPUT, PS3_01_REPORT_ID , buf );
_ return;
}_
void PS3_USB::setBDADDR(unsigned char * bdaddr){
char buf[ PS3_F5_REPORT_LEN ];
_ buf[0] = 0x01;
buf[1] = 0x00;
for (int i=0; i < 6; i++){
buf[i+2] = bdaddr;
}_
Usb.setReport( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_F5_REPORT_LEN, PS3_IF, HID_REPORT_FEATURE, PS3_F5_REPORT_ID , buf );
_ return;
}_
void PS3_USB::getBDADDR(unsigned char * bdaddr){
Usb.getReport( PS3_ADDR, ep_record[ CONTROL_PIPE ].epAddr, PS3_F5_REPORT_LEN, PS3_IF, HID_REPORT_FEATURE, PS3_F5_REPORT_ID , buf );
_ for( int i=0; i < 6; i++){
bdaddr = buf[i + 2];
return;
I understand this is a lot of code and difficult to check. I'll keep trying different things to solve the situation and if I am succesful I'll reply again.
Thank you
Rafael_
