FQBN: esp32:esp32:esp32s3
Using board 'esp32s3' from platform in folder: C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
Using core 'esp32' from platform in folder: C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1
cmd /c if exist "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\partitions.csv" COPY /y "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\partitions.csv" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\partitions.csv"
cmd /c if not exist "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\partitions.csv" if exist "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32s3\\partitions.csv" COPY "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32s3\\partitions.csv" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\partitions.csv"
cmd /c if not exist "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\partitions.csv" COPY "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\tools\\partitions\\default.csv" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\bootloader.bin" ( COPY /y "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\bootloader.bin" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sample_file.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32s3\\bootloader.bin" ( COPY "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32s3\\bootloader.bin" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sample_file.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sample_file.ino.bootloader.bin" "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.8.1
Creating esp32s3 image...
Merged 2 ELF sections
Successfully created esp32s3 image.
cmd /c if exist "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\build_opt.h" COPY /y "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file\\build_opt.h" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\build_opt.h"
cmd /c if not exist "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\build_opt.h" type nul > "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\build_opt.h"
cmd /c type nul > "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/file_opts"
cmd /c COPY /y "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3\\sdkconfig" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sdkconfig"
1 file(s) copied.
Detecting libraries used...
C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/defines -IC:\Users\Sai Kiran\OneDrive\Documents\Arduino\sample_file -iprefix C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/include/ @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/includes -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/qio_qspi/include -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32s3 @C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE/build_opt.h @C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE/file_opts C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE\sketch\sample_file.ino.cpp -o nul
Generating function prototypes...
C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2405/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/defines -IC:\Users\Sai Kiran\OneDrive\Documents\Arduino\sample_file -iprefix C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/include/ @C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/flags/includes -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32s3/qio_qspi/include -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\cores\esp32 -IC:\Users\Sai Kiran\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\variants\esp32s3 @C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE/build_opt.h @C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE/file_opts C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE\sketch\sample_file.ino.cpp -o C:\Users\Sai Kiran\AppData\Local\Temp\212095911\sketch_merged.cpp
C:\Users\Sai Kiran\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Sai Kiran\AppData\Local\Temp\212095911\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32s3-elf-g++" -MMD -c "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32S3_DEV\"" "-DARDUINO_VARIANT=\"esp32s3\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/defines" "-IC:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file" -iprefix "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/include/" "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/includes" "-IC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/qio_qspi/include" "-IC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\cores\\esp32" "-IC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32s3" "@C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/build_opt.h" "@C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/file_opts" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sketch\\sample_file.ino.cpp" -o "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sketch\\sample_file.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/file_opts"
Using precompiled core: C:\Users\Sai Kiran\AppData\Local\arduino\cores\3c0b7ad6dee7efeffc7465216b92050b\core.a
Linking everything together...
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32s3-elf-g++" "-Wl,--Map=C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.map" "-LC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/lib" "-LC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/ld" "-LC:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/qio_qspi" -Wl,--wrap=esp_panic_handler "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/ld_flags" "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/ld_scripts" -Wl,--start-group "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\sketch\\sample_file.ino.cpp.o" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\cores\\3c0b7ad6dee7efeffc7465216b92050b\\core.a" "@C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.elf"
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.bin" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.elf"
esptool.py v4.8.1
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\tools\\gen_esp32part.exe" -q "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/partitions.csv" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.partitions.bin"
cmd /c if exist "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\libraries\\Insights" "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\tools\\gen_insights_package.exe" "C:\\Users\\Sai" "Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE" sample_file.ino "C:\\Users\\Sai Kiran\\OneDrive\\Documents\\Arduino\\sample_file"
cmd /c if exist "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\libraries\\ESP_SR" if exist "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32s3\\esp_sr\\srmodels.bin" "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE\\srmodels.bin"
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.9.dev3/esptool.exe" --chip esp32s3 merge_bin -o "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x0 "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.bootloader.bin" 0x8000 "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.partitions.bin" 0xe000 "C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.bin"
esptool.py v4.8.1
Wrote 0x400000 bytes to file C:\Users\Sai Kiran\AppData\Local\arduino\sketches\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.merged.bin, ready to flash to offset 0x0
"C:\\Users\\Sai Kiran\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32s3-elf-size" -A "C:\\Users\\Sai Kiran\\AppData\\Local\\arduino\\sketches\\40D1A71B11DEABD78691BD4476C856AE/sample_file.ino.elf"
Sketch uses 298956 bytes (22%) of program storage space. Maximum is 1310720 bytes.
Global variables use 19704 bytes (6%) of dynamic memory, leaving 307976 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM6
A fatal error occurred: Could not open COM6, the port is busy or doesn't exist.
(Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31))
Failed uploading: uploading error: exit status 2
