Can't Compiling
i want testing modul ESP8266 but can't compiling, im Using Arduino Uno R3 and Arduino 1.6.9
 *  This sketch demonstrates how to scan WiFi networks.
 *  The API is almost the same as with the WiFi Shield library,
 *  the most obvious difference being the different file you need to include:
#include "ESP8266WiFi.h"
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
  Serial.println("scan start");
  // WiFi.scanNetworks will return the number of networks found
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
      delay(10);
  Serial.println("");
  // Wait a bit before scanning again
  delay(5000);
error like this :
Arduino: 1.6.9 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from C:\Users\crash_team\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
                 from C:\Users\crash_team\Documents\Arduino\libraries\ESP8266WiFi\examples\WiFiScan\WiFiScan.ino:6:
C:\Users\crash_team\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:26:19: fatal error: queue.h: No such file or directory
 #include <queue.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
can help me ?
The ESP8266WiFi library is written for use with the ESP8266 core for Arduino:
You can't use it with the Arduino/Genuino Uno you're trying to compile for.
That library is a part of the ESP8266 core for Arduino core and it makes absolutely no sense to have it installed to your sketchbook folder. I recommend you to delete it to prevent future problems.
If you want any further help you'll need to explain exactly what you're trying to accomplish.
pert:
GitHub - esp8266/Arduino: ESP8266 core for Arduino
I want to send data to cloud from arduino using ESP8266 module as its module, and initially before getting there, I want to create script for ESP8266 configuration to connect to my network.
But when I try the result like that.
Generally for that usage of the ESP8266 I recommend this library:
It's certainly possible to accomplish what you're trying to do but there are some potential difficulties. Whether these affect you is impossible to say without more information. Good luck!
